Go Back  RCU Forums > RC Airplanes > Aerodynamics
thrust angles >
thrust angles
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
thrust angles
Old 01-31-2003 | 06:39 AM
Default thrust angles
how are you guys getting the 3 degrees right and down thrust in your airplanes??? I have a half-***** method of adding two washers right and two washers down...but I would like to be more exact..how are you guys accomplishing this task?
Old 01-31-2003 | 11:41 AM
Default Ernst
Hi Jeremy,
Ernst Mfg. makes thrust plates that mount to the firewall behind the engine mount. Very effective.
http://www2.towerhobbies.com/cgi-bin...ST&S2=&S3=&S4=
Old 01-31-2003 | 02:01 PM
You can size the shim required to tilt the engine exactly how much you want. For a distance between mounting bolts of W shim thickness/W = .017 per degree of tilt
For example let W= 4". The tilt produced is 1.09 deg per 1/16" washer.
