Go Back  RCU Forums > RC Airplanes > Aerodynamics
canards???? >
canards????
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
canards????
Old 02-11-2003 | 07:47 AM
Default canards????
What kind of thrust angles are reauired for canard ships (tractor or pusher)? Which would be better for a canard a tractor or a pusher? The canard is supposed to fly at a higher angle of attack from what I know. How much higher? Is 4 degrees too much?
Any help is apriciated.
Old 02-11-2003 | 07:48 AM
Default canards????
Moderator pls. move over to design.
Old 02-13-2003 | 10:10 AM
Default canards????
A canard should not fly at a higher angle of attack than any other aircraft, but because the canard is at a higher angle of attack than the main wing that will stall first. This means the nose will drop and that protects the main wing from stalling.
If you put a clark Y on a canard aircraft and a conventional aircraft I would suggest they will stall at the same angle. The canard maybe at a slightly lesser angle because of the disturbed air from the canard tips.
Most full size EZ type canard aircraft are being built with a dihedral canard these days to try and stop this.
Old 02-17-2003 | 12:20 AM
Default canards????
Most carnard airplanes usually have the engine in a pusher configuration, although there's really no reason why you can't have a tractor mounted carnard plane.
