Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Wingloading 101 help >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 08-01-2008 | 09:33 AM
rainedave's Avatar
Default RE: Wingloading 101 help
One thing about smaller models is that one ounce can represent almost 10% of the AUW, as with my 10.5oz Sure Shark.
BTW, Mr. Hanson, is the Richard Hanson on this cover you? Or, a relative of yours?
David
ID:	1001951   Click image for larger version
Old 08-01-2008 | 06:55 PM
WMB
Hi all, I have a 4*40 with wing loading of 18.12 oz/sqft and a Midwest Semi scale Zero with about 23.2oz/sqft. Wingspan real close to each other. Figures based on advertised wing area. The 4* I can usually grease in on landing, flies nice. The Zero is difficult to land. Try to land a little hotter helps but hard to do. Too slow and it stalls. Balance feels good on both when inverted. The Zero flies great! I just can't land it smoothly. Any tips on this?
Thanks, MikeB
Old 08-01-2008 | 09:53 PM
rmh's Avatar
rmh
ORIGINAL: rainedave
David
No -I am on the cover of Model Aviation , Dec 1982
Old 08-02-2008 | 02:12 PM
rainedave's Avatar
Are you sure?
David
Old 08-02-2008 | 03:39 PM
ORIGINAL: WMB
Thanks, MikeB
Check the wing volume loading of each, it is much more indicative of the flyability of a model than wing loading is. When that WVL gets much above 11 the plane gets pretty touchy.
Old 08-02-2008 | 03:52 PM
  #31
ORIGINAL: chuck993
Don't all Cubs fly like a trainer though?
Nope. Just the ones set up that way.
To see what I mean look up Dick Schram "The flying Professor".
If you can get a video of him flying his routine you simply won't believe it.
I've seen a lot of full scale aerobatic routines but none was as entertaining as his.
_____yes, I know he is no longer with us_____
Old 08-02-2008 | 05:37 PM
  #32
WMB
What is WVL and how is it calculated? thanks
Old 08-02-2008 | 06:49 PM
  #33
rmh's Avatar
rmh
ORIGINAL: rainedave
Are you sure?
David
typo - 84
Old 08-03-2008 | 12:11 PM
  #34
Here is a JPEG with graph and formula
