Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Help with CG math >
Help with CG math
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Help with CG math
Old 08-26-2008 | 11:40 AM
ChrisAttebery's Avatar
My Feedback: (15)
Default Help with CG math
Hey guys,
This is more of a mental exercise, but it could save me alot of tinkering in the garage. I have a 5 pound plane that I want to move the CG back. I can move one component that will reduce the moment on the nose by 6 in/oz. another will remove 13.3 in/oz. The question is knowing these moments can I calculate how far each will move the CG rearward?
Thanks for your help,
Chris
Old 08-26-2008 | 12:08 PM
My Feedback: (15)
Default RE: Help with CG math
Found it:
CG shift = (weight of object moved) * (distance moved) / (total weight)
