Go Back  RCU Forums > RC Airplanes > Aerodynamics
 How to calculate induced angle of attack and downwash >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 01-17-2009 | 10:25 AM
Default How to calculate induced angle of attack and downwash
Hi,
I am not new to aerodynamics, and I have had my go at designing radio control aircraft, and have recently gotten a book called Mechanics of Flight by Warren F. Phillips. It is a great book, but it is a bit too hard to understand for me, who is 17 years old.
My question is, can you please write down for me a formula for calculating the induced angle of attack cause by downwash of the wing/vorticity of the wing. Also, I would much appreciate if you would state what all the variables in the formula stand for- as when we use different notations in complex formulae it gets very confusing.
Please, please, please explain me how to find the induced angle of attack as I am trying to figure how much twist to give to my airplane's wingtips so that the induced drag is not oh so significant!!!
Best Regards,
Sparrow99
Old 01-17-2009 | 11:32 AM
Default RE: How to calculate induced angle of attack and downwash
Try to get this book: [link=http://www.amazon.de/Aerodynamik-reinen-Unterschallstr%C3%B6mung-Fritz-Dubs/dp/B0000BHJZF]Fritz Dubs: Aerodynamik der reinen Unterschallströmung.[/link] PP. 119-130. Great book, quite easy to understand, Swiss author.
Old 01-17-2009 | 11:53 AM
Thanks for the recommendation, but after spending 120 dollars on buying Mechanics of Flight which is a dictionary of calculus equations I don't quite understand- I will stick with reading that and also the internet. If you have the book, can you please summarize how to fins the induced angle of attack and the formula for it please?
Lafayette.
Old 01-17-2009 | 12:24 PM
Well, in short, induced AOA = lift coefficient / pi * aspect ratio [rad], that is for elliptical lift distribution. For other cases it's rather complex. Won't help you much either because you can't do that much about induced drag with washout. So I'd still recommend getting a good textbook
Old 01-17-2009 | 04:46 PM
rmh's Avatar
rmh
I would swap the books for a few good foam models and see W T H actually happens.
Old 01-17-2009 | 06:24 PM
BMatthews's Avatar
Lafayette, in general as model builders we choose to put washout into the wingtips for tip stall delay related handling reasons instead of drag reasons. Although I think most realize that some drag advantage comes with its use. With the way our models fly drag avoidance is just not something we need to worry about other than in a few VERY specific cases such as thermal sailplanes.
Old 01-17-2009 | 06:35 PM
removed
