Go Back  RCU Forums > RC Airplanes > Aeroworks Vendor Forum
Reload this Page >
Aerowroks 20cc trainer
Aeroworks Vendor Forum This is the place to go for all your questions concerning anything Aeroworks. Rocco, Mark, and the rest of the Aeroworks staff will be manning this forum so that they can answer all your questions.
Old 04-02-2015, 01:48 PM
  #101
Aero-Works
Aero-Works's Avatar
Hello Dan,
Yes, the plane can be converted to a tail dragger and then you can use the DLE35RA. or you can modify the nose gear and mount it from the rear of the firewall and this will make room for the rear mounted muffler.
Please feel call me if you have more questions
Thank you
Rocco
Aeroworks
Aero-Works is offline
Old 04-02-2015, 08:08 PM
  #102
mrdhud
My Feedback: (48)
mrdhud's Avatar
Originally Posted by Aero-Works
Hello Dan,
Thank you
Rocco
Aeroworks
Thanks for the fast reply Rocco I'm looking forward to the plane I will be using it to teach my nephew to fly. Glad to hear I can make the modify the gear so I can use my DLE35.
mrdhud is offline
Old 04-22-2015, 03:33 PM
  #103
mrdhud
My Feedback: (48)
mrdhud's Avatar
Well, my trainer arrived last week and I have to say I’m impressed with everything about this ARF. I decided to go with a Zenoah G26 instead of the DLE I had to cut the cowl for the carburetor but that’s OK by me plenty power for this bird. The maiden flight went very well today. Aero-works you did good on this one.
mrdhud is offline
Old 04-22-2015, 04:18 PM
  #104
shorte
I agree that is what I was going to put in mine zenoah g26 very reliable and easy no batteries run all day and did they ever put flaps on it.
shorte is offline
Old 04-22-2015, 06:56 PM
  #105
mrdhud
My Feedback: (48)
mrdhud's Avatar
Shorte, No flaps with the G26 and a 16/8 prop it comes in pretty fast wish it did have flaps.
mrdhud is offline
Old 04-23-2015, 02:38 AM
  #106
Planejaw
My Feedback: (53)
Originally Posted by Larry AK cUB
Planejaw I just flew mine for the first time yesterday with a dle 20 crosswinds were high but took off and flew fine.I noticed the rollout was longer than what im used to.So I programed in flapperons my question is did you mix in any down elevater as well.....thanks...Larry
Larry,
I didn't mix in any down-elevator with flaps. Found that with much more than a few degrees of flapperons, you really need to use the rudder to make directional corrections on final and to help level the wings. I'll have to experiment more with it this season. I'm sure hoping Aero-Works comes up with a flap version and then we can retro-fit the new wings on our ships.
Planejaw is offline
Old 04-23-2015, 04:31 AM
  #107
Acs_guitars
Acs_guitars's Avatar
Once you learn how to slow the GT down on approach, you can land at close to walking pace without flaps... Mine slows down just fine with the DLE 30 and an 18x10 prop. A guy at my field did one electric and added flaps, mine w/o flaps lands just as slow if not slower. I still wish it had flaps though but more for a dive break when towing gliders.
Acs_guitars is offline
Old 04-23-2015, 08:17 AM
  #108
Aero-Works
Aero-Works's Avatar
I would like to be able to offer a flap version wing for he GT Trainer for future productions and am looking into it.
Thank you for your comments,
Rocco
Aeroworks
Old 04-26-2015, 06:29 AM
  #109
BarracudaHockey
BarracudaHockey's Avatar
Rocco, we just got the Great Planes Escapade in for review.
It has the full length ailerons like the GT but there's another servo bay and the flap is connected to the aileron by two wood pins. Cut the pins and install the servo and you have flaps, leave them be and you have ailerons.
Something like that would be perfect.
BarracudaHockey is online now
Old 04-27-2015, 06:59 AM
  #110
Aero-Works
Aero-Works's Avatar
I will look into it!
Rocco
Old 04-27-2015, 01:53 PM
  #111
Larry AK cUB
Planejaw thanks for the info here are a few pictures of my gt with fults nose gear and 4.5" tires and a link to some flying video looking at the nose wheel.The dle 20 is plenty powerfull for this plane it has enough power when inverted to hold down elevator and bring the plane back upright.Vertical climb rate is very good not unlimited but very good.Weighs in at 12.5lbs https://www.youtube.com/watch?v=2HSweXhp_cg
ID:	2092608   Click image for larger version
ID:	2092609   Click image for larger version
ID:	2092610   Click image for larger version
Larry AK cUB is offline
Old 12-08-2015, 06:54 AM
  #112
warpsflyer
This plane does not need flaps. I fly mine with a DLE 30 with a 19x10 prop. It takes off in 10-15' depending on wind. The only thing this plane needs is a better nose gear. It is a little flimsy and wants to nose over. No fancy stuff needed, I am using a LIFE 2500 mah pack and HRC 645 servos. Keep it simple.
warpsflyer is offline
Old 12-08-2015, 06:59 AM
  #113
BarracudaHockey
It doesn't "need" flaps.
But I've flown one that has been modified with them and its a hoot to play with them so the option would be nice. It depends on the use too, we use it to glider tow, dropping the flaps and pointing straight down to get setup for the next tow is useful
Old 01-17-2016, 04:39 PM
  #114
bikerbc
What does "need" ever have anything to do with what we want ?
bikerbc is offline
Old 01-17-2016, 05:19 PM
  #115
bikerbc
Do you need the extra weight of the G26 to help it to balance? The G26 is a good deal heavier than something like the DLE20 .or the DLE 30 .. I have both engines and they both run great. The G26 is nice because it dosen't need an extra battery pack. I do like that but I think the DLE 20 is my favorite because of the power it puts out for it's size . I don't really mind charging a battery for it as I need to charge batteries anyway . I have the G 26 on my H9 Taylor Craft and it balances it perfectly and has the right amount of power . I have A DLE 30 on a scratch built Spit and it has just enough power to fly it .
bikerbc is offline
