Airplanes - Full Scale Discuss full scale airplanes here
What is this plane
Old 04-26-2007 | 08:21 AM
Default What is this plane
Can anybody tell me what kind of plane this is?
ID:	672546   Click image for larger version
Old 04-26-2007 | 08:26 AM
Sport_Pilot's Avatar
Default RE: What is this plane
Combat version of the T-6. What is that anNA 50?
Old 04-26-2007 | 08:47 AM
Here it is.
http://www.airventuremuseum.org/coll...P-64_NA-50.asp
Old 04-26-2007 | 10:12 AM
LowFlyBye's Avatar
ORIGINAL: Sport_Pilot
It is not a T-6 or T-6 variant. This is a P-64 which was made by North American so it has some similar looks, but a completely different plane.
The "combat" versions were actually gunnery trainers and were in fact SNJ, Harvard, & T-6 (B) models with various armament setups consisting of a fixed, syncronized 30 cal. on the top of the cowling, another fixed 30 cal. on the inboard leading edge of the right wing (some can be found on the left), and one removable, rear facing, aim-able 30 cal. that could be operated by the backseater by swiveling the rear seat aft.
They were primarily used for gunnery training, but some did in fact see combat.
Most of the "combat versions" have the rear gun removed today in the interest of weight and space, but you will occasionally find one at the airshows with the modified rear canopy and the aft gun still in place.
ID:	672600   Click image for larger version
ID:	672601   Click image for larger version
Old 04-26-2007 | 10:22 AM
Wrong, anybody familiar with that plane can tell you it shares a large number of parts. It is in fact a T-6 with a turtle deck, shorter wings, and larger engine. Not an entirely differant airplane. The stock T-6 had the capability of using real guns and needed no modification, just the installation of the guns. However it is not really good for anything much above training with guns, though used as an attack aircraft in some contries it was a poor choice. The P-64 and NA-50 are the same plane and is considered the combat version of the T-6, a T-6 with guns is not actually good for combat, too slow and underpowered.
Old 04-26-2007 | 11:58 AM
LowFlyBye's Avatar
Sport_Pilot
I am very familiar with the T-6 and have quite a few hours in 2 different versions including the SNJ-5B, SNJ-6. I will admit that I am not as familiar with the P-64, but if memory serves me correctly there were only a half dozen of them ever built and only 1 survivor remains today. There are however many replica models built from modified T-6 which is obviously what is captured in the above picture. This is no different than the majority of the various Kate and Val aircraft seen today.
Just because aircraft look similar or share a few parts does not make them variants, or the same aircraft. Case in point...RV-8 -vs- Harmon Rocket -vs- F1 Rocket. They look a lot alike, have some interchangable parts, but are very different aircraft.
Read the information in your own link before contradicting yourself...
"The North American P-64 is often referred to by Warbird lovers as an “export fighter version of the AT-6 Texanâ€, North American’s ubiquitous WWII trainer. In actuality, the P-64 is similar to, but not the same as the AT-6. The most significant differences include a shorter wing, the aircraft length, and a more powerful engine. The parts for these aircraft, though similar, are not interchangeable. "
Sport_Pilot
I think I stated that it was primarily a gunnery trainer, but did see some combat.
Sport_Pilot
No argument there.
Old 04-26-2007 | 12:39 PM
Dispite the article, my understanding is that most parts except the changed airframe parts and engine parts are indeed interchangeable. Besides that the aircraft is a direct modification of the T-6, not a new design borrowing from the T-6 as you imply.
Old 04-26-2007 | 12:45 PM
My Feedback: (60)
The airplane pictured in the original post is neither a P-64 nor an NA-50 but is in fact a modified Harvard. The link that "Sport Pilot" posted is to that of the EAA's P-64 which is the only surviving example of its type but is not the same aircraft posted by "touch and go". Their have been quite a few Texans/Harvards/SNJ's modified to resemble a P-64 or NA-50. More info on this airplane and others can be found here:
http://www.warbirdinformationexchang...d1d65b63c873ee
Old 04-26-2007 | 08:47 PM
Taildragger726's Avatar
It is a replica of a NA-50 owned by John Shell in western NC. I was based at the same airport with Dr.Shell for years. Has a geared 1340 and dual controls. He is in the final stages of completing a "Super Six" for the colection.
Old 05-14-2010 | 03:43 AM
Too bad he sold that NA-50 to fund the Super-6. Would have been nice to have both.
Old 05-28-2010 | 05:11 PM
I think that's a Seversky P-35 painted in military colors. Or at least a close derivation of it. Those lines seen in the photo are so familiar because this plane was the starting point for the design of the Consolidated P-47.... Seversky was one of the firms 'consolidated' into the Consolidated Aircraft Corporation
Old 05-30-2010 | 02:34 AM
My Feedback: (60)
Not a Seversky, see the previous replies.
Old 05-31-2010 | 07:50 PM
Moretrim's Avatar
That is sweet !
