Another Drone Pilot does it Again
#1801
My Feedback: (49)
Use Of Drone By Lifeguards At Local Beach Reveals Chilling Look At Sharks Near Shoreline
Wonder what the FAA thinks of this???
http://losangeles.cbslocal.com/2015/...ear-shoreline/
http://losangeles.cbslocal.com/video...lipId=11601799
#1802
First Hobby People were selling something for spying, and now Sports Authority is up to it as well.
http://www.sportsauthority.com/produ...uctId=60817256
Aarrrgh!
Aarrrgh!
#1803
#1804
My Feedback: (49)
So you are calling all modern Pattern flyers "Girly-Men"?
I should have said all but the Pattern flyers...we all know they are the real He-men, master of the universe type... Now if they fly IMAC with a Carden, they are God like... LOL
Too nasty to publish but LCS: ounce again I agree with U scary ain't it.
#1805
My Feedback: (209)
#1813
HD, I use that formula all the time...My wife is blonde and that's how I get more airplanes...its the art of explaining that's key...Hmmm, once or ounce... which ever is correct...their head starts hurting from trying to figure out what you are saying, you can pretty much do anything. Don't try it on a brunette...you may end up hunched over coddling your manhood...works on redhead sometimes...but if it fails much worse consequences than with brunettes...Stay safe, blondes only, is my recommendation...
#1814
My Feedback: (209)
#1815
My Feedback: (49)
"WHAT"?
PLZ Explain how Mass can easily be easily converted to volume, and then volume can be converted to length by multiplying two dimensions by 0.
#1816
#1819
My Feedback: (209)
"WHAT"?
OH now I get it I often use a similar formula but as taught in advanced algebra (where my highest grade was an "F") U can prove anything by dividing by not Multiplying by ZERO. Thanks for the explanation.
#1821
Liter = 1000cc's = 10cm x 10cm x 10cm = Kilogram
Milliliter = cubic centimeter = 1 gram
Metric Ton = 1 meter x 1 meter x 1 meter = 1000 kg
Then try to convert cups and quarts to cubic feet and pounds.
#1822
My Feedback: (49)
The amazing metric system is the the recognized unit of measurement in all countries except for the US, Burma and Liberia:
specific gravity of a liquid to change a gallon to lbs.
U are WRONG: Except fof when U convert grams of WATER a spific gravity of 1 to cc.s
U can not convert cubic any thing to grams kilograms or even LBs. unless U know the
the actual weight of the substance per cubic what ever.
Example:
a liter maybe 1000 cc's but 1000 cc of Oil does not weigh the same as 1000 cc of water,lead,feathers.
That's like saying there are 32 oz in a quart x 4= 128 Oz in a gallon.
But there are 16 ounces in a lb. so a quart would weigh 2 lbs. so a gallon 128 ozs / by 16 oz = 8 lbs.
Well if this were true a gallon of water would weigh the same as a gallon of Gas
Water 8.33 lbs where gas weighs 6.5 lbs / gallon.
U can not mix CUBIC measure with DRY measure and expect to be correct.
#1823
My Feedback: (55)
Should arm the Quads with Depth Charges full of Shark Repellent.
#1825
Originally Posted by [email protected]
i don't believe what people say about the drones i think they are just a bunch of talkers
Is this a sort of "pictures , or it didn't happen" disbelief on your part ? Do the guys who fly them have to post videos for you to believe ? I'm just curious , I guess , of exactly what it is that you don't believe ?
