time to stop the dromes..........NOW
#176
At two and three nautical miles, the resolution is 3.53 and 5.30 feet respectively. So it's entirely possible that an airline pilot could easily spot all but the smallest RC aircraft at considerable distances.
#178
This leads to the elephant in the room no one is talking about. These drone sightings are accepted as factual with no thought that the pilot could be wrong. The commercial and civilian pilots are being "trained" to spot drones, to look for them. Now, I am afraid everything that was at one time a seagull as example is becoming a drone. Can you imagine a quad keeping up with a landing commercial jet? Really? Its zipping along fpv at 150mph aside the landing 737? I am not saying that there has not been idiot operators and that there has not been any times that they have not been somewhere they shouldn't. I just think its foolish to accept drone near miss sightings as absolute truth 100% of the time. Example. This has not happened, so ok ok call it straw man but...Im at my club flying my 60 size p-47. I am probably flying at most 150-200 above ground altitude. Just flying. Along comes Cessna at around 900-1100 feet above ground. They look down. They see my plane. They report it as a near miss. Is there report questioned? Can I defend myself? Well, yeah maybe I can..but in reality right now its a witch hunt for anything unmanned in the air. FPV or line of sight
#179
#181
Who administers the tests do U endorse the FPV pilot like a Turbine waver. I think the AMA should require all instructors to be certified and all AMA members should have a biannual every 2 years from a designated examiner or certified flight instructor just like full scale pilots ... Now let's talk about the 3rd class medical certificate for RC Flyers. along with a certificate to solo any RC type flying object. with special endorsements for FPV, Quads, jets, planes over 25 lbs, gasoline motors, and Lectrics of 5S or more.
That should ruffle a few feathers. LOL OOPS for got the endorsment for Helis sorry
#182
#183
Some of that does not make any sense. Now a RC sailplane has right of way over a full scale aircraft. And flying fields near airports must be in communication with the airport. Clearly not well thought out.
#184
Second, resolution means that at two nautical miles, someone with 20/20 vision needs at least 3.53 feet between two objects to see them as two objects. Less than that and the just see one.
Third, in a 1952 test at the Naval Air Test Center in Patuxent River MD, pilots were able to detect an F8 Bearcat, with 120 degree aspect at 17-20NM (and they weren't told "where" to look).
So I'm pretty confident in many of the reports. Not all to be sure. But many.
#185
Banned
My Feedback: (8)
Right...in the past. What we have not always had to deal with is small RC aircraft with the ability to climb several thousand feet in all types of visibility conditions. That something bad hasn't happened already doesn't mean it might not happen in the future. We've all seen the increase in reporting of near misses etc over the past few months. I don't know that 400 ft is the right number, but leaving it "unlimited" isn't realistic.
#186
First, pilots "see and avoid" for a living. They're constantly looking outside for traffic. If it's a multicrew plane, that's two sets of eyes looking outside.
#187
My Feedback: (49)
And that's if they are not heads down in the cockpit or fixated on their touch down mark.
Very seldom do U see but a flash the instant of a bird strike at 150 kts. Most birds
especially larger birds like Hawks and geese try to dive out of the way when U come up
from behind them.
from behind them.
#188
#190
My Feedback: (49)
From another Forum Thread by HD:
goto this URL https://www.fltplan.com/AwMainToAppr...SEARCH&end=end
Under Approach Charts (U.S. & Canada insert the 3 letter Identifier of the airport of concern, or if unknown fill in the other criteria.
Down load the approach plates for your airport. Print them out as large as U can. Study the charts especially the plan view and the profile with the decent altitudes. Now for a good idea how these approaches affect your RC field go to Google Earth activate the RULER and draw the plan views of each segment of all the approaches that might affect your RC field. Save each segment so as to be able to draw others with out loosing those already drawn. Don't for get about the circle to land criteria for altitude but usually only applies to with in 1 mile of the air port. the Missed approach may be of concern also. From this U will get a better picture where the aircraft doing actual approaches in less than VFR conditions and these Practicing in VFR conditions will or should be with in your proximity to your RC Field. Remember that many time even out side the 5 mile radius there can be extensions were planes might be flying lower than usual.
U must remember that in VFR conditions that 99% of airplanes with in 5 miles of an air port where they intend to land they willl/should be at pattern altitude i.e. usually 1000' AGL but could be as low as 800' agl anywhere in that 5 mile radius from the center of the airport. Some times at pattern altitude even farther out than 5 miles. Then their is always special VFR at a operating towered airport witch is 1 mile visibilith and clear of clouds. If your field is one of these it may behove the club to aquire an aviation capable receiver only tuned to the frequency used at that airport as it will give U a mental picture of the air traffic in your area. Reason for receive only is unless U are licensed it is Illegal to use an Aviation radio.
#192
Banned
My Feedback: (8)
So do the guys flying multirotors and FPV not part of a club and not an AMA member read these forums or care about our hobby? They probably do
Should the AMA be forced on everyone to be able to fly at an RC field? No, and it's not that way now.
If our flying fields are set up with a "bubble" do we still need the AMA ins? I'd say yes, for sure
#193
Anybody actually believe that there will be FAA enforcers monitoring our flying fields? The enforcement actions will be almost always post significant incident.
IMHO, if you fly at an AMA club field and do not violate the AMA Safety Code or the Advanced Flight Systems documents you have next to nothing to worry about except for your flying skills and the other pilots on the flight line.
#194
My Feedback: (49)
#195
First, pilots "see and avoid" for a living. They're constantly looking outside for traffic. If it's a multicrew plane, that's two sets of eyes looking outside. If flying an instrument approach in visual conditions, PAC is flying instruments, the other is outside. A sizeable number of the reports were from dual piloted A/C.
SNIP
SNIP
Yet I am not so certain that the pilots of the last 30 years are so interested in what is going on outside the cockpit. When I became an airline person after 14 years of watching what is happening out there, along with my flight duties, I am not very certain that even today's pilots are very interested in what the outside world brings to their minds. My eldest son is a UAL pilot after gaining his 20 years retirement in the USAF. He is not so happy with today's FAA methods that pilots must fly auto-pilot almost all the time. When I was a 2nd officer and then co-pilot, and definitely in my Captain time, I never gave up my look-outside time, and most of my time was hand-flown. I had many 1st officers that had a difficult time managing to keep even a short time of looking outside. THEIR eyes were much -- IN MY OPINION -- far too set within the forward cockpit. Now that was almost 20 years ago, yet I get reports on the lack of keeping up with outside while flying airliners. In fact I try to keep from using airliner tickets as much as I possibly can. When I instructed in the USAF's T-38, my last 2 years of USAF, again IMO, I considered that far too many young men's eyes were on the instrument panel rather than side to side, as I was taught by those days-of-old when one was taught to keep moving that head if one wished to see that other fellow first!
Just my thoughts of this old fellow!
#196
My Feedback: (49)
Mr. Franklin, you are definitely an extremely well versed in the Aviation subject and I do admire your abilities, experience/s and knowledge.
#197
Just a hunch, but I suspect the FAA is encouraging the use of FMS more during enroute and approach because they can hold speed, altitude, and route with much less variation than when someone is hand flying. I gives the system much more predictable flight paths. Especially now that the commercial FMS can handle a route that includes not just point to point, but the complete route, with altitudes, planned decent points, etc. I honestly see this more driven by increasing air congestion, particularly on J routes in/out of major cities. There's been a number of articles on how the FAA is really struggling to handle the demand, which is why they're so heavily committed to the new ATC system (whenever it gets rolled out).
#198
So the initial solution by the FAA will be to require LEO to enforce. As if the local law enforcement isn't already understaffed and overworked. It is idiocy to have LEO take time away from working on murders, rapes, assaults and burglaries to petrol the flying sites looking for citizens flying toy airplanes!!!!!!!!!!!!!!!! PRIORITIES CRIMES AGAINST PEOPLE FIRST!
Now some here (JohnShe) have advocated a STASI like citizen spy solution where if you see somebody flying FPV in the street you call the police. I can see it now get half price AMA membership if you turn in a FPV violator. Not for me............................and I hope not for you!
#199
Thank you, the FAA does not have the manpower to even manage the current demand for full scale, where will the resources to manage sUAS come from? In the current budgetary situation a request to staff up will be met with tough questions about the $400 billion and climbing cost and years late delivery of NEXTGEN. And some state that NEXTGEN was not designed to handle commercial UAS so where will that money come from? In the scope of national priorities where will toy airplanes fall?
#200
spin, spin, spin Who are you to allow to say what I "mighty" allow? We KNOW from your prior posts that you are a self declared protector of the citizens against injury from toy airplanes. Got a badge (other then Cub Scout?)
