Frequency Scanner?
MA
The scanner that I use for personal use is an Icom R3 scanner. It is PC programmable, pocketable and a lot less costly than the Icom 3000 type scanners used by AMA districts. It is much more sensitive than the Hobbico and it has a spectrum analyzer function that lets you see any RC or non-RC signals adjacent to the one you are monitoring in a graphical manner.
ORIGINAL: bhorton
Can someone recommend a frequency scanner for a small club? What type of scanners does the AMA own? Our club wanted something with better range than the Hobbico scanner.
Therefore what a scanner picks up on the ground may not be all that an aircraft is subjected to when a hundred or more feet in the air. Just to keep in mind. [sm=what_smile.gif]
It worked nice.
