 Top Flight AT-6 >
Top Flight AT-6
Top Flight AT-6
Old 03-27-2011 | 05:15 AM
Default Top Flight AT-6
I just purchased a Top Flight AT-6 and need check the CG. Can someone tell me where the CG points are on this plane?
Old 03-28-2011 | 03:39 AM
Default RE: Top Flight AT-6
I don't know whether you have the ARF or a kit-built model but it makes no difference. The CG is 4 1/4" back from the wing leading edge at the point where the wing fairing is. That is also the point where the wing transitions to a slight taper at the front. I've used this CG and it works fine.
Good luck......and you'll enjoy her.
