TT Easy Trainer Engine Question >
Old 08-15-2003 | 09:56 PM
Crash Master's Avatar
Default TT Easy Trainer Engine Question
Got the TT Easy Trainer (WS=61", Wt=5.5lbs) with the semi-symetrical wing. It calls for .40-.46 2S or the TT54 4S.
I want to hang a 4S on this and have a Magnum .52 and ASP .61 in 4S. Will the Mag pull this with some authority or can I get away with the .61?
Thanks for any comments,
Old 08-15-2003 | 11:10 PM
HighSierra's Avatar
You'll be fine using anywhere from a .50 to a .72 size 4-stroke
