 Four*60 engine question >
Old 04-20-2005 | 03:16 PM
Test005's Avatar
Default RE: Four*60 engine question
I have a os70-fsII on my 4*60 kit but haven't had good enough weather and time to test fly it yet.
Did some research and found that most people prefer a .91-fs, but that the .70-fs will do for normal sport flying.
I'm convinced the .70 will be perfect for me. I'm not into aerobatics and just enjoy zipping around.
I figure I'd go 1/2 throttle with the .91, so why not use the .70 and go 2/3 throttle? ... Well, time will tell, but theoretically I like this combination
Old 04-20-2005 | 04:18 PM
thanks for the reply Test005- let me know how it goes with the maiden flight. good luck!
Old 04-20-2005 | 04:25 PM
exeter_acres's Avatar
Wow...digging up an old thread....
I should think the plane would fly just fine with the .70...not a power house or a 3D monster, but it should fly fine...
I have run a Magnum .91 and a Saito 1.00 in mine... and it flies (well....Duh, but you know what I mean).......
about the only time I need full throttle is when I am pulling out of a spastic hover (well gimme a break I'm still learning)
or when I need an endless upline......
but for basic flying around, the .70 would be fine....
the plane floats very well.... takes off quickly....
Worst case..fly it with the .70, enjoy it, but if you feel it isn't enough...put a bigger engine on later......
Old 04-20-2005 | 04:38 PM
Thanks Ex- thats pretty much what I figured too. Its just a big wing for a .72 4-stroke, and my main concern is that it wouldn't be too marginal on power. I will eventually upgrade the engine. Will be nice to hear from Test on how his flies. The Magnum .91 sounds like a great match for this plane. Saito 100...wow. I've even read about people putting 120s in it...YIKES!
Old 04-20-2005 | 05:16 PM
Test005's Avatar
From my (theoretical) point of view:
1. General sportflying, basic manouvers; .70 will be OK
2. For 3D flying, better/unlimited vertical performance; .91 is the choice
This question is as much "How do you fly?" than "What's the best engine for this plane?"
I'd classify my sessions as "General sportflying" and my needs, skills and lack of interest in aerobatics/3D doesn't call for excessive power, just enough to get off the ground and cruise around with the occasional loop, roll and fast-low-altitude fly-by.
For me buying a .91 and hardly use it over 60% would be a waste of $, while the .70 would be "boring" for the hardcore 3D pilot that need maximal *omphhh*
Old 04-20-2005 | 08:37 PM
  #31
DTB's Avatar
DTB
My Feedback: (15)
ORIGINAL: Test005
Well put Test005, that is exactly why I have a YS .91FZ on mine with a APC 15x6 prop. I flew a friend's 4*60 with a Saito 61 (I think that was it) and it was very very slugish, but I am use to the power of mine also, so I had to take that into account also. I think a .70 is the lowest I would go also.
Old 04-23-2005 | 09:59 AM
  #32
I have the saito 100 on mine and would reccommend it in a heart beat. it weighs less than the TT .91 and will hover the airplan pretty dog -gone good. unlimited vertical.
Old 04-26-2005 | 05:34 PM
  #33
well, Ive decided to go with the Saito 72 since I have it, keep the build nice and light, and run 20% nitro and an APC prop. this should be the most this setup could possible offer, and if Im not happy with how it flies I'll upgrade to a .75 2-stroke or a .91 4-stroke.
-ron
ps. Test --- let us know how your 4-star flies! good luck with the maiden =)
Old 05-27-2005 | 02:24 AM
  #34
Test005-
have you maidened your 4*60 yet? Im just finishing mine up, hope to fly it this weekend. =) Weather looks promising!!!
Old 05-30-2005 | 03:20 AM
  #35
Hi all,
I just ordered a 4*60 and am having a tough time trying to decide on an engine. I've read this post and have noticed that not too much was said about 2 strokes. As I'm not familiar with 4 strokes I have kinda settled on a 2 stroke. Cannot decide between an OS .61FX or a Super Tiger .75. Any help would be appreciated. I don't do 3-D and I don't need a rocket, but I don't want a slug either. I need some guidance. Thanks.
Old 05-31-2005 | 12:48 AM
  #36
I fly mine with a 91 fx 2 stroker. It is definitely not overpowered, plus you have the extra muscle when you need it. Personally, I wouldn't go with anything less than a 90 in it. Just my .02$
Old 05-31-2005 | 02:10 PM
  #37
I've got a Tower 60 in mine and it flies fine. It will do Basic IMAC aerobatics, but it is limited on vertical. If you are just looking for a good all-around flier, then the OS .61FX will be okay. The ST .75 will give you a little more power if you'd like. Personally, I like OS engines, but for the price, I'd probably get a Tower .75. I've had good results with their 60 size engines (I've got 2), and I have a 75 in the box waiting for a home.
Kerry
Old 05-31-2005 | 11:52 PM
  #38
Thanks for the input guy's. I too have also had nothing but good luck with OS engines, had a bad experience with a Tower .46, not saying they are all bad, but the one I had gave me nothing but fits. Even after having almost a gallon of fuel through it. Call me stubborn, but I was determined to get it to run right. But it finally won, and I gave up on it. I could get it to idle good, had good transition, and good top end. But get it ten feet off the runway and it would start running like a piece of crap. But back to the subject, will stay with a 2 stroke and it will be an OS. Thanks again.
