 Four*60 engine question >
Old 09-08-2003 | 03:28 PM
Default Four*60 engine question
First off I'm the new guy so bear w me.. Second I really have used the search feature and haven't found what I was looking for..
So w that said I have a Thunder Tiger 90 (That IS the 2 stroke correct?) And have a option to by a new four * 60.
Is this too much engine? I have seen 90 fourstrokes ect. but not this.. Just like to hear if this is a good match or not.
Thanks guys!
Old 09-08-2003 | 05:35 PM
Default RE: Four*60 engine question
This is my first post under the new rc universe, so bear with me. I have had two 4* 60s and powered them both with 75 two strokes. The first one was a Supertigre and the other is Tower hobbies 75. They seemed to have plenty of power with a 13x6 prop and I think the 90 would be a little overpowered. However I am no expert on this as I am your every day sport flier.
Old 09-08-2003 | 07:16 PM
I don't think a 90 Super Tigre is too much for the 4*60. I would certainly use throttle management when necessary.
I have one with a Sport Jett .76 and Dub's tuned pipe, which should be comprable to a 90 (or so, LOL) and it flys great. Actually, it's a rocket, but that's what the left stick is for, yes?
There are guys that have 4-S 120's on them with no problem.
Good luck and have a ball!
Old 09-08-2003 | 07:34 PM
Geez o peas man..On a 4*60!? Wow if thats the case I'm sure the 90 would be fine! I wonder if the empennage would be better off with a wire support brace?
Thanks!
Old 09-08-2003 | 07:51 PM
Couldn't hurt to put some hard-points in and install some flying wires, but I don't think it necessary.
When I over-power an airframe I look at the firewall first -- drilled and pinned and triangle stock installed. Next, it's the wings -- great bond between both halves plus the seam is fiberglassed. I do (always) reinforce the vertical and horizontal stablizer at the fuse with tri-stock above and below.
Other than that (and good throttle management), never had a problem. (knock-on-wood, LOL)
Old 09-08-2003 | 08:03 PM
Let me ask you one more question Crash_n_Burn about flight characteristics..
How does this *Super-sizing* effect slow and approach flight w the Four *, or the like?
I guess w a proper CG it shold be more or less the same, just maybe a tad less floaty due to weight?
Big Thanks!
Old 09-08-2003 | 08:25 PM
Maybe a tad less floaty, but in reality, the few extra ounces doesn't make any real noticeable difference. It still floats unless your final is long and flat.
I balance at the aft recommended CG point and it seems to handle just fine there. Needed to use a double battery pack behind the rear cockpit former in order to get it to balance without any additional (unnecessary) ballast.
With a .60 or a .90 (or a 120) it will do just about anything that you ask it to do. It is a wonderful plane and one of my favorites.
Old 09-08-2003 | 08:28 PM
Hell I never thought of doubleing the battery pack! Thats a great idea!
You'll have to forgive me..I've been out of rc for a while! Heck My Extra300 has I don't know how many Oz. of lead in the tail! [:'(]
Thanks again!
Old 09-08-2003 | 09:12 PM
Ed_Moorman's Avatar
A .91 works great. I have had them with an OS .91FX and a Magnum .91XLS with a Performance Specialties Ultra Thrust muffler. Can you spell vertical. Knife edges all day.
I put the rudder and elevator servos under the stab, side mounted the engine, full cowl, clipped 2 ribs and added back rounded tips, moved the gear to the wings, added length to round off the fin and stab. It is now a mock WW II Kawasaki Tony.
Excellent flying plane.
ID:	60116   Click image for larger version
ID:	60117   Click image for larger version
ID:	60118   Click image for larger version
Old 09-08-2003 | 10:01 PM
carrellh's Avatar
If it is a Thunder Tiger .91, it is a four stroke.
They do not make a .91 two stroke.
They do make .61 and 1.20 two strokes.
A .91 four stroke is recommended for the plane.
Old 09-09-2003 | 07:45 AM
Wow Ed cool Job.. Did you decide to Mod a perfectly stock 4* 60 or did you have to decide to Umm...reinvent one after a unfortunate mishap ? (Its just a lot of changes is all!)
Why the elevator servo under the stab and how have you beefed up the airframe?
carrellh, no it definately is Not a 4 Banger...So it must be a Super Tiger I suppose(Obviously not been seen by me in a while!) Definately a 90 and definately a 2 Stroke.
Old 09-09-2003 | 11:04 AM
Thanks again!
< Message edited by Walt1 -- 9/9/2003 2:30:27 AM >
Here is my .02$. I have a Saito 91 in my 4*60, and I think it is the perfect engine for this platform. Balance is always an issue with this plane because of its long tail moment, so I put my engine as close to the end of my Dave Brown engine mount as I dared. I also substituted a 4*120 landing gear for the soft stock gear, and I came in right at the balance point by just moving the battery under the tank. The plane flies great and is a absolute jewel to land. Just line up on final, and let her settle right in the groove. BTW this is my second plane, and this is a great step up from a trainer.
Old 09-09-2003 | 11:44 AM
Hello; I have been flying my 4*60 for a few years now (maybe three) with an old OS90 4 stroke, and am very happy with it. Another fellow at our field flys a 4*120 with a super tigre 90, that also works great. I love that huge prop and teh things I can do because of it. The fellow with the 4*120 zooms around at full throttle all the time, and can't be convinced to throttle back and enjoy the slower speed handling. I don't know really how that plane handles except at high speed. The ST 90 does that pretty well, I don't know if that engine won't run cleanly at lower revs. I suppose if you want to scoot around and never attempt low speed handling, I suppose a big two stroke will do that. I p[refer the four stroke myself, I enjoy flying at the slow end oof the flight spectrum.
Old 09-09-2003 | 02:38 PM
I sure hope it does cause I expect I'll be going at 1/2-3/4 throttle more than half the time!
Old 09-09-2003 | 06:41 PM
Tweet's Avatar
I'm putting a Saito 100 in mine, which is the same weight as the Saito 91. Can't wait to try it out.
Old 11-13-2003 | 09:10 PM
DTB's Avatar
DTB
My Feedback: (15)
I've got a 4*60 with a YS .91FZ mounted up front which gives the plane the power of a 1.20 size motor. This combination allows me to take off and go directly vertical with no hesitation until I decide that is high enough and level off. My 4*60 was a kit which allowed me to modify the plane more than an arf could be (well easily anyway). Extra support, bracing, 1" extra on rudder and elevator, dual elevator servos, pull-pull rudder system, front hatch compartment, Modified rudder on top to act like an "Extra 300" rudder acts with the counter support on top while flying and a few other mods that were done. Hovering is no problem what so ever with this YS engine. Knife edging is very easily accomplished. Just remember that the 4*60 is not a pylon racer, so be easy with the throttle in a dive if you use an over powered motor, but the vertical performance is outstanding.
I would suggest the following motors in order of preference..
YS. 91FZ
YS 1.10FZ (more costly than the .91FZ)
Saito 1.20
Saito 100
Saito .91
OS 1.20
OS .91 w/pump
OS .91
All 3 brands listed are very good motors and any one of these motors above will fly the 4*60 with ease and much fun. Vertical performance would be great also, but landings could still be made at a snails pace with full flaps deployed.
My thoughts on the matter.
Enjoy your 4*60,
DTB
Old 11-13-2003 | 09:17 PM
Mokken's Avatar
My Feedback: (63)
Have several people at my field with the fourstar .60 and they are mostly powered by .91 fs and a couple have Saito 100's on theres. Either engine is fine for that plane, not sure about TS since I've not seen one fly with one.
Old 11-13-2003 | 09:19 PM
Wow..I thought this thread had passed away a long time ago!
Well a update is in order I guess...I did purcashe the Four*60 and a week later bought a Satio 100 from the same guy.
So far not a single bad thing to say about that set up. MORE than enough power !
Old 11-14-2003 | 05:45 AM
I fly this airplane with a ST 75 on it, and it flies ok. A 2 cycle 90 type will fly it great!!! As someone else mentioned, just use the throttle as necessary.......
Old 11-14-2003 | 07:37 AM
Thats one thing I like about the four stroke...I feel ( at least to me.) That a four stroker is less likely to load up and quit after a 5 minute run at 1/4 -1/2 throttle.
My two strokes I alway felt the need to clear them out...
Old 11-17-2003 | 07:59 PM
Hi all. I have a carl goldberg tiger 60 arf. my problem is I bought a magnum 60 2stroke. I almost did not made it in the air.
I was thinking of overpower, but my question was a 2 or 4 stroke.
Old 11-18-2003 | 07:06 AM
I have a Four * 60 with a Thunder Tiger 91 four stroke. I am very satisfied with the combination. Take-off at less than half throttle. Good acceleration and throttle transition. Just a great match for the Four*60.[8D]
Old 11-18-2003 | 08:59 AM
My Feedback: (17)
Ditto what JohnS just said. I have the same exact setup and 100% happy with it. Good luck and have fun.
Old 12-12-2004 | 11:59 AM
Alright,
I was considering a thunder tiger 91 and a saito 100. the saito is 100 dollars more and not that much bigger. i was wondering if the TT 91 will infinitly hover the four*60 and pull out ok. i am willing to pay more if that is what it takes to be able to hover. but if the TT will do it, i will go with that!
Old 04-20-2005 | 02:00 PM
anyone flying / flown the 4*60 on a lower displacement 4-stroke? Im wondering how it flies on a .72 4s or a .60 2s. Im building one now and I have a Saito .72 available to use. Problem is that's on the LOW end of the recommended engine range. I hear about people taking off at 1/2 throttle and hovering it with their .90s and .100s.
Now, I KNOW a 72 4s is not ideal! =) But I don't want to do vertical maneuvers, just enough engine to do some lazy aerobatics and not be (unsafely) marginal on power. I do build very light, so it won't be a clunker. Yes, I know I could pick up a 2s .70 for under $100, or a Magnum 4-s for under $200, but really I just don't have the $$$ right now. =)
-ron
