GP Christen Eagle II
RE: GP Christen Eagle II
I honestly have to say that I like the covering on the Pitts much better. Of course all I can see are the pictures. One thing I didn't like reading about was that the fuse is shorter than the Pitts. I found that my Pitts was a bit squirrely on take off until I got the perfect touch with the rudder. Probably just me, but have to wonder if this will be even more pronounced with the shorter fuse??
As for assembly time, gee, I found it took much longer than 10 minutes to set my pitts up at the field. I didn't like this so I broke down and bought a trailer.
My Feedback: (10)
The one thing that scares me is the tail wheel linkage directly connected to the servo arm. Won't this introduce a lot of unwanted shock to the servo?
To RFW and Runover:
I've been using this type of tailwheel linkage set up for years, without the fuel line shock absorber. It works great! Very positive groung handeling and I have yet to note any servo problems used on the rudder/tail wheel set up.
To counteract the "squirrel" tendencies of the Pitts, try holding full up elevator as you advance the throttle. Use the rudder with the tailwheel oround for steering. As the plane comes up to speed, let off the elevator to allow the tail to rise. The rudder isn't effective until a relatively fast ground run has been acheived. It can still be a handful, especially on landing or crosswind. You really have to stay ahead of a full scale Pitts. This model isn't any different. That's why I suggested to one post about waiting awhile before getting into one of these.
Sure is fun to fly, though.
Silversurfer
Silversurfer
My Feedback: (29)
I had my Pilot 1/3.5 scale Pitts side by side with the GP Pitts and inside and out it IS the same plane with a few changes for the better! The Eagle will be the same as the Pilot Eagle. What a way to revive an old favorite. The Pilot flies great so I know the GP will also. My Pilot Pitts has had a Saito 270 and a G-62 for power and it handles the G-62 fine and balances without problem.
#31
ORIGINAL: 14th_Reaper
Wouldn't it be amazing though, if when they released this project, everything was perfect? Everything was exactly where it was supposed to be? No shipping damage? No recalls, no mismatched paint on the cowl and wheelpants? All hardware was perfect, no need to run to the hobby shop for missing parts or replacements for cheaply made junk?
I know what you mean by the second run Silver. But, just for once, wouldn't it be nice if they didn't release what amounts to a beta test release but a truly ready to perform masterpiece? I don't mean to pick on GP because almost all companies in all endeavors release items that shouldn't be yet.
#32
Tail wheel direct linkage to the rudder servo is my preferred method also. Much more positive control on steering just make sure you use lots of expo to soften it. At the low speeds you use the tail wheel, the rudder is ineffective and has no force on it and vice versa.
#34
My Feedback: (13)
NY
My LHS has one too. It had a sold sticker on it but I got a chance to check it out. Same great quality as the pitts. I'm probably getting a little picky but they did'nt continue the blue in the feather pattern on the horizontal stab. My LHS said Great Planes will not ship any more to them until December...
Chads
Chads
#35
Went down to LHS and saw the Eagle II. I have always wanted one and did not even know they were coming out. Very cool. I bought it on the spot. LHS price was $379.00. Quality and build looks very good. I am planning to put my 2.2 Webra Bully glow or maybe my OPS 60cc glow twin, have not decided yet. I have a local guy here who has the Pitts with a 3W-75. A little over kill but that's what everyone is doing. I fly here with Mike McMurtry who owns LHS and his son is Sean (World Team). So TOC stuff is big here and having big power is the norm. I'm sure the Bully would haul the crap out of it.
Comments?
Don
Comments?
Don
#38
I have a left over First Place 2.4 engine I was thinking about putting in the Eagle... For those of you that already have one, is there any room in the fuse for a smoke tank?
#39
I have recently purchased a christen eagle 2. built of course... built 2 other planes tho...no where near the size of this.... 1/3 scale ... anyways. i need an actual plan of this model.... anyone have this? i hope so. doin some repairs due to a crash it took.... minor but necessary. also i am looking to purchase a used engine to fit this thing....looks like she had a 91 cc in it, but not sure. the cylinders both came out from the cowl maybe an 1/2 inch.... bolt pattern is weird. if anyone can help me with this please message me or email me for a pic of it...
thank you
thank you
#40
My Feedback: (23)
From the shape of the Cabanes, this isn't the Great Planes Christen Eagle. Maybe a Pilot kit?
In any event, Great Planes or any other ARF maker doesn't have plans available for any of their models.
91 cc engine? Never heard of that either.
Exactly how big is your plane? Wingspan? Length? They may give us something to go on.
#41
NC
Looks to me like you have the old EZ Kit. I have one here that I am taking the motor out of to put in the GP ARF.
The EZ Kit was an arf with no plans. Mine has a Saito 270. Its also difficult to repair this kind of foam covering. Good luck with the repairs
Its a heavy plane that needs to be flown all the time and can take a big motor
#42
My Feedback: (13)
NY
If it has a wingspan of approx. 84" it is probably the kit previously sold by Eagle Aviation and now by Rick Boyer in PA. The kit that Rick Boyer sells is essentually a copy of the Pilot models version but only larger...
Chads
Chads
