Ultra Stick Radio Programming >
Old 04-23-2002 | 12:59 AM
Default Ultra Stick Radio Programming
Hi All
I have been playing with this for two days now and I'm getting frustrated, so I thought I would ask the group. I'm setting up my JR 8103 radio for a Ultra Stick and can not adjust the end points on the Flap channel. I can set all the other end points in the TRVL ADJ screen but it has no effect on the flap channel. Any help would be appreciated.
Old 04-23-2002 | 01:44 PM
Rob, had the same problem. Here is what I got when I called Horizon. The manual is incorrect.
Addendum to 8103 Program for Ultra Stick:
1. Go to function list
2. Highlight D/Flap T. and hit enter
3. Activate Pot 6
4. Return to function list
5. Put your 3 position flap switch in the bottom position
6. Select Program mix 5 or 6 (whichever is empty)
7. Set flap pot at full negative value
8. Select Offset and press "clear/store" (value should be –222)
9. Go back to function list
10. Select D/Flap T.
11. Set pot 6 to "inh"
12. Return the flap switch to the top position
13. Go to your flap mix and set the rate until your ailerons are level
14. Have fun flying your Ultra Stick!
Old 04-24-2002 | 01:38 AM
Thanks for the instructions. I will try them out tomorrow night and see if I can get it to work.
