How are those phoenix models????????
#51
KS
Holy crap, what do you say to someone after something like that, and your plane is still for all intents and purposes, just fine? Thats funny.
#52
Hi
I am from Kolkata, India and I would like to buy one Phoenix Funstar very soon, it is available India. But I would like to know if I use 46AX or 55AX with this model how to fit the engine into cowl? Also I would like to know what size of 4S Engine I can use on this model, but only OS Engines please.
What about this 56FS-a 4-Stroke Engine? http://www.osengines.com/engines/osmg0956.html
Is this engine enough for 3D flying and hover? What size of prop I should use for best 3D/Hovering performance? Please help me if you can.
Regards,
Rajib
Regards,
Rajib
#54
Hi Rajib, I hope you're enjoying shopping for your Phoenix Models Funstar 3D ARF. You should find either the .46 AX two-stroke or the F56-a four-stroke from O.S. Max to be ideal engines for the Funstar 3D. You could use the .55 AX two-stroke or the FL-70 four-stroke if you'd like, but the smaller displacement engines should provide enough power to pull straight up from a hover. An APC 12x4 propeller would be a good 3D prop for the .46 AX. The F56-a would probably turn a 13x4 well.
Good luck and good shopping!
#55
Thank you……………
I have decided to buy Phoenix Funstar 3D with O.S. 46AX ABL engine as per your recommendation. But about the propeller I have some questions. I have found 4 propellers which are 12x4. Please tell me which one is the best.
1) APC 12x4 Sport Propeller: http://www3.towerhobbies.com/cgi-bin...?&I=LXMJ90&P=7
2) Zinger 12x4 Pro Zinger Wood Propeller: http://www3.towerhobbies.com/cgi-bin...?&I=LXESM2&P=7
3) Zinger 12x4 Wood Propeller: http://www3.towerhobbies.com/cgi-bin...?&I=LXLG20&P=7
4) Master Airscrew 12x4 K Series G/F Nylon Propeller: http://www3.towerhobbies.com/cgi-bin...?&I=LXEXD4&P=7
Also I would like to know why 12x4 propeller, why pitch is so less? I am asking about this because I have no idea about 3D models, I have learn 3D model flying on R/C Flight Simulator G4. But in real life it will be my first 3D model so I am looking for best suggestions from all of you since you people are experienced in 3D flying many years.
O.S. recommended propellers for 46AX ABL: 10.5x6, 11x6-8, 12x6-7, use 10x6 for break-in.
This propeller recommendation chart I have found on Tower Hobbies website.
Engine Size 2-Stroke 4-Stroke
.049-.051 5.5x4, 5.5x4.5, 6x3, 6x3.5, 6x4 N/A
.09 -.10 7x4, 7x5, 7x6 N/A
.15 7x6, 8x4, 8x5, 8x6, 8x7 N/A
.20 -.25 8x6, 8x7, 9x4, 9x5 9x4, 9x5, 9x6, 9x7
.29 -.35 9x6, 9x7, 9x8, 9.5x6, 10x4, 10x5, 10x6 N/A
.40 9.5x6, 10x4, 10x5, 10x6, 10x8, 10x9 11x6, 12x6
.45 -.50 10x8, 10x9, 11x4, 11x5, 11x6, 11x7, 11x7.5 N/A
.60 11x5, 11x6, 11x7, 11x7.5, 11x8, 11x9 11x8,11x9,12x6,13x6
.71 -.80 12x6, 12x8, 13x6, 13x8, 13x10, 14x8 N/A
.90 13x6, 13x8, 13x10, 14x6, 14x8 11x9,12x8,14x6
1.08 14x8, 14x10, 15x8, 16x6 N/A
1.20 14x8, 15x8, 16x6 14x8,15x8,15x10,16x8
1.5 16x8, 16x10, 18x6, 18x8 N/A
1.8 18x8, 18x10, 20x6, 20x8 N/A
2.1 20x8, 20x10 N/A
2.7 -3.0 22x8, 22x10, 22x12, 24x8, 24x10, 24x12 N/A
Please I need all of your valuable advice, thank you in advance for helping me.
Regards,
Rajib
2.1 20x8, 20x10 N/A
Regards,
Rajib
#56
Hello
I wish to buy one Phoenix Funstar model and these all accessories mentioned bellow, please help me to choose right products. Some products I have selected but about some products I have no idea what to use and which are best.
ARF Model: Phoenix Models Funstar 3D 46 ARF .40-.46, 52.7"
http://www3.towerhobbies.com/cgi-bin...&I=LXEDP0&P=ML
Engine: O.S. 55AX ABL
http://www3.towerhobbies.com/cgi-bin...&I=LXNMD1&P=ML
Muffler: Macs Muffler O.S. .40-.46/TT .40
http://www3.towerhobbies.com/cgi-bin...&I=LXZ652&P=ML
Propeller: APC 12.25x3.75 Sport Propeller
http://www3.towerhobbies.com/cgi-bin...?&I=LX1577&P=7
Servos:
Ailerons & Throttle - Futaba S3151 Servo Digital Sport BB
http://www3.towerhobbies.com/cgi-bin...&I=LXFKZ8&P=ML
Rudder & Elevator – Futaba S3152 Servo Digital Standard Hi-Torque
http://www3.towerhobbies.com/cgi-bin...&I=LXHKB0&P=ML
Please let me know if I have missed or choose any wrong products. I would appreciate all of your valuable advice.
Regards,
Servos:
Regards,
#57
ORIGINAL: Rajib
Hi
Regards,
Rajib
Hi
Regards,
Rajib
I've assembled 3 Phoenix models and seen a number of others. None were 3D models. But all were heavier than advertised. And 3D models benefit from extra power because they often need it. My opinion is that a .56 four stroke would not be enough. I would suggest for a 4stroke, most models advertised for .46s would need at least a .70 four stroke.
#58
You may not need the muffler but it's up to you. Of all the Phoenix planes I have my favorites are still the Strega and Dolphin.
#59
AZ
We race the Stega's at our field. Put YS 1.10s, build up firewall, landing gear bays and horizontal stab, and go really fast. I take the stock canapy off and replace with a real p-51 canapy.
G
G
