Do you inspect your new ARF or RTF prior to launch
On two purchases i have discovered goofs which left un tended would lead to a crash on one the esc wires werent properly soldered to the contacts. On another the wing servo was loose, i attempted to adjust the throw on the aileron arm and the servo moved side to side. On one plane the servo arm was out of center i didnt want to use sub trim and the servo was buried under the skin. Took out a knife cut the servo out which was glued in with gobbits of of glue
My Feedback: (18)
PA
Absolutely. I go over every part to determine any defects, & during the assembly process check each area for fit & alignment. I generally make out a short list of areas I feel need some mods to enhance reliability, performance, & stability. Servo throws, wiring connections, motor run w/wattmeter, control surface movements, clevis & horn connections, & landing gear mounting parameters. It has paid off handsomely with superb maiden flights. Don't hesitate to do a bit of homework & evaluations.
Denny
Denny
NJ
they tell you there built to last.........now the word last can mean lots of things...........time isnt one of them.........covering cut to short,,,,,,holes to big,,,,,,,,,glue thats made for paper,,,,,,,,landing gear thats made for paper planes,,,,,,,,,,hinges that are made for paper planes.........push rods that bend.........and the list gos on...........should you check.........its your money and time.........
