Best Model for Windy Conditions ???
NJ
Looking for recommendations on a good model to buy that is least effected by windy conditions. I don't expect to fly in 30 knot crosswinds but want one I can fly rather than go home on those marginal days.
I assume the larger the better and not a flat bottom wing. I am at the beginner to intermediate stage and want to do basic sport flying and mild aerobatics. What do you recommend?
Normally I would suggest a plane which would "slice" through the air, but these are for the more advanced flyer. Since you are a beginner to intermediate, I might suggest a stick model with a shoulder wing.
My Feedback: (9)
The wind blows all the time here. Your right to an extent, the bigger the better. It's actually the higher the wing loading the better. My 1/4 scale Suhkio dosn't mind the wind.
My buddy's 1/4 scale Cub is grounded at 10 knots. My suggestion for a less exspensive model? I flew a .60size Ultra Sport from Great Planes for years. With a ST.75 for power.
The wind didn't bother it. I flew at several times in a 30-40 mph wind. It was a handfull but was controlable. Later David
have a thundertiger 40 sport (low wing mag 52 4 strk) does fine in 15-20 mph winds
My vmar chipmunk did ok also with an irvine 40 diesel this one came thru wind plus
a rain squall out of nowhere . The chipmunk was lost 2 weeks later due to a "radio hit"
My electric slow stick is a blast in wind can do harrier landings in head winds however
once of the ground it blows all over the place
MO
If your still looking for a high wind plane go with an over powered ultra stick . I have the 40 and the 120. have flown the 40 size in +35 mph wind , can land it backwards in head wind . with a pro 46 it can handle the wind and you don't have to wrestle with it .
WYLDMAN.
WYLDMAN.
My Feedback: (7)
TX
[link=http://www.theworldmodels.com/superstunts60.htm]Super Stunts 60[/link]
My Feedback: (7)
TX
As mentioned, higher wing loading will result in more stability under windy conditions.
Isn't that the exact opposite of a glider which you fly in windy conditions?
Anyway, I don't find this to be the case....I find the total size of the plane/total weight of the plane to have a much larger effect. I understand that a "model" airplane with high wing loading supposedly "penetrates" the wind better. However, a large crosswind on a 2 lb model with the smallest of all wings (and thus a very high wing loading relative to other 2lb models) and a mega engine to make it fly gets blown all over the field. I find that a 10 lb model will hold up much better in a lot of wind than a 2 lb...no matter what the wingloading is.
...unless you talking about the "total" absolute size of the wing-loading number instead of the "relative" size of the wing loading.
My Feedback: (9)
ComCity, What do you think would be better to fly in the wind? A 10# 1/4 scale Extra or a 13# 1/4 scale Extra? I think the heavier would be a lot better. On final for example with a 10MPH steady wind. All at once you get a extra 10MPH gust. The 10# model will flair up more than the 13# model. I cant give you the science but I have felt it on the sticks. Later David
