Seagull Extra 300S >
Seagull Extra 300S
Seagull Extra 300S
Old 05-31-2002 | 03:25 PM
Default Seagull Extra 300S
Although this plane is great in the air, it is a pain in the butt trying to taxi. Does anyone else have a problem of contant nose over. I am on a bumpy grass field, but if you can get the speed up quickly, you can usually prevent nose over. If you slow down, forget it.
The other problem was the first landing (which wasn't hard) ripped the bottom of the fuse out. No plywood to speak of. It is now heavily reinforce and I put in 1/4X20 nylon bolts; however, if the landing is 100% perfect, kiss the landing gear goodbye.
I also had the firewall come off. Once again, construction not great.
I replace the .46 engine with a Saito .72 and love the extra power. A word of caution is full throttle decent. Had some flutter but saved it.
Old 05-31-2002 | 03:52 PM
Hi Scott,
Try raking the gear forward to prevent nose-over. I don't know this particular model but, if they're aluminum or glass gear a shim under the back edge will accomplish this without a lot of work.
An old trick us WWI types use when not overly concerned with scale realism (the real ones nosed over a lot too).
Old 05-31-2002 | 10:55 PM
Glass two piece gear. Worth a shot with a shim.
