Arf Wing Joining
Does anyone reinforce the wing joints on an arf glue together wing? If you do - whats the best way? WM Super Stunts just arrived and I would like some tips.
My Feedback: (55)
One thing to look out for is to make sure the dihedral brace (joiner) is
a snug fit and that you are getting a flush fit of the two root ribs. I've heard
some of the joiners on some ARFs fit pretty sloppy. A little sanding should
get both wing ribs flat to each other.
I treat ARFs just like the ones I'm building from scratch. If it doesn't look
strong enough reinforce it. Just don't get carried away and make it too heavy.
They're designed to fly, not crash.
tommy s
tommy s
I'm more pleased if the dihedral brace isn't too tight. Lets me align the wing halves. If it's too tight, the build has to be perfect. Epoxy will fill any small voids.
The question was,
If you really feel the need to reinforce you can :
1. remove a stip of covering on each side of the rib joint, so you have a place to put your fiberglas tape. Use a soldering iron tip to melt the covering, rather than trying to cut with a blade.
2. cut your 'glas tape to fit, and
3. epoxy the tape to the center joint. Do it top & bottom, and recover the exposed side of the wing.
Good luck,
Dave Olson
The question was,
Good luck,
Dave Olson
Banned
When I remove covering to allow fibregalss taping a jont... I peel it back instead of cutting it free. If you are careful... you can peel it back... then do the glass work.... then iron it back on. don't even need any covering to patch it.
