 Sig 4 star 60 arf pushrod question >
Old 03-16-2004 | 04:01 AM
Chris-_-Memphis's Avatar
Default Sig 4 star 60 arf pushrod question
what pushrods did everyone find worked best w. the 4*60 arf..i dont like making bends and stuff... and i dont want to fool w. any of that semi flexiable crap... any suggestions? also what -if anything- should i replace on the 4* while i am ordering stuff? anything weak?
Old 03-16-2004 | 04:33 AM
Banned
Default RE: Sig 4 star 60 arf pushrod question
The stock pushrods in the kit are fine... no problems with them at all.
Old 03-17-2004 | 09:22 PM
mstroh3961's Avatar
Default RE: Sig 4 star 60 ARF push rod question
My ARF had a problem with the stock push rod dragging in the outer housing. I ran Sullivan blue and gold nyrods through the existing outer housings. sand the ends of the blue outers where they exit the stock outers and use some medium CA to secure them. Work much smoother than stock rods.
Old 03-18-2004 | 09:20 AM
Walt and Sage's Avatar
That is interesting, as mine also worked just fine without ANY binding..
Must be a Monday Friday thing...
Walt...
Old 03-18-2004 | 06:13 PM
mstroh3961's Avatar
Default RE: Sig 4 star 60 arf push rod question
I just got a bad ARF. Have had to correct several flaws that the first 4 Star didn't have. The former at the rear of the wing saddle had almost no glue on it. and where the push rod housings were glued in, the former was pushed to the rear causing the housings to cross in the center of the fuselage behind the radio bay. I believe the dragging push rods were a result of the kink caused by being glued the way they were.
