 4*60 same size as ALPHA 40? >
Old 06-16-2004 | 04:12 PM
Default 4*60 same size as ALPHA 40?
I just got my 4*60 and its the exact same size as my alpha 40 :/ . I was hoping for the 60 to be a bit bigger
Old 06-17-2004 | 06:08 AM
WCB
Default RE: 4*60 same size as ALPHA 40?
You'll like flying the 4* trust me. I have flown the 4* (a friend's) and now I'm assembling the ARF. It flies great and will do anything you want to do. Good luck with yours.
Old 06-17-2004 | 10:12 AM
Ok, but the 4*40 must be really small?
Old 06-18-2004 | 06:20 AM
WCB
A few guys at my club have had 4* 40's and the consensus is that they don't fly nearly as well as the 60 size. Most smaller planes don't fly as good as the larger sized version.
Old 06-18-2004 | 09:31 AM
Deadeye's Avatar
ORIGINAL: EObrad
You would think so, but it really isn't. The 120 size isn't that much bigger than the 60, either. Something like 3/4" wider tail chord, maybe 2 inches bigger on tail span. You can get the wing specs for these planes on the Tower site.
Old 06-18-2004 | 08:21 PM
That four star 60 may not be bigger than your alpha, but it's about 3 pounds heavier and about 30 mph faster. Keep the rates low for the first few flights and enjoy! I just built my second, it's the plane that always makes the trip to the field!
What were you planning for an engine? If you can swing it $$, a .91 four stroke is a nice match. A 75 two stroker does a good job too.
