Lanier 540 T 120
I have that combo. Using an APC 16x8 and 20% nitro with an OS F
plug. Plenty of power. Great flying plane.
You'll have to do some cutting on the firewall for the stock muffler. Also reinforce the firewall and landing gear plate. I found the tail wheel assembly to be way too soft.
I got it when it first came out last year. Maybe they made some changes since then.
Good luck.
Good luck.
IL
I know this is a trick question, so I will try to guess...............It will have Saito power!!! Did I guess right? Huh? Did I win anything???
Sorry, too many CA fumes and 15% smoke does this to a guy! Pete
My Feedback: (7)
If you choose to place the elevator servos in the tail, the plane will come out fairly tail-heavy with the Saito 150 or 180. To solve this, a lot of people are moving the cowl out about an inch and adding some balsa and covering to extend the turtledeck and underbelly an inch or so to compensate. It makes balancing a WHOLE lot easier and eliminates / reduces the hacking you must do to the firewall to make room for the muffler.
I tried the factory-recommended elevator setup and it was just terrible. I put Hitec 225 BB servos in the tail for the elevator.
Another problem: If you're installing a pull-pull rudder, you have to open up the covering on the bottom to get to the former in front of the fin and work on that former. There is a hole in that former, but it's too high to run a pull-pull straight through it. You will need to open it up some to make room for the pull-pull cables to go straight through.
With these mods and the suggestions above, you'll have a great flier. Also, folks seem to like the 18x6 props for 3D.
Was it a bent manifold or was it cut and soldered? I think I read where someone cut a slice out of the manifold then bent it together and sealed the opening with silver solder.
