 g.s.p. hellcat >
g.s.p. hellcat
g.s.p. hellcat
Old 09-08-2004 | 08:11 AM
Default g.s.p. hellcat
HI I,M LOOKING FOR A SET OF RETRACTS FOR MY GIANT SCALE PLANES F6F HELLCAT.ANYBODY HAVE THOUGHTS ON WHAT KIND,ALSO HAS ANYBODY TRIED NELSON PAINTS.IF SO WHAT DO YOU THINK OF IT.
THANKS. FFDQ
Old 09-08-2004 | 10:19 PM
My Feedback: (27)
Default RE: g.s.p. hellcat
I purchased a set of century jets for this plane. Most times it helps to replace the rotating spring with a stronger one.
Old 09-09-2004 | 01:57 AM
orcrest's Avatar
I have fitted a set from ESM or KMP depending on where you buy them. They are air up and spring down and look reasonably strong. You do have to do a little bit of trimming work to fit them, as well as take out a bit of the spar to fit the air cylinder but I don't think it weakens it significantly. I haven't flown yet but will post a report when I do. Check them out at www.kmp.ca/new.htm
Cheers
Da Orc
Old 09-09-2004 | 07:40 AM
HI THANKS GUYS FOR THE INFO.CENTURY JET MAKES A SET JUST FOR THIS HELLCAT.I THINKING ABOUT GOING WITH THEM,BUT STILL HAVE A OPEN MIND.
THANKS
