sig rascal 110 engine and servos
I was wondering if anyone has installed an O.S. 108 on a Sig Rascal 110 if so how it flies? Also I was wondering does this plane really need high torque servos?
FL
I have Rascal with a little gasser init and it fly's very real like.It's close in size as to the 1.08 so I would think you will be fine,not over powered but ok.As to the use of servo's I would recommend a servo in the medium torque range for the alerons and at least 70 oz for the elevator and rudder,these surfaces are quite large in size.I've had good luck with the Hitec 635's karbonite servo's.
