 GP Cub arf refueling >
Old 09-21-2004 | 07:25 PM
Default GP Cub arf refueling
I'm assembling a GP Cub ARF and looking for ideas on how to refuel since it has a cowl. Anyone built one using a refueling fitting from Dubro or how about fuel dots? Either way, where and how did you mount these refueling devices? Pix would be great. Would rather not mount anything to the cowl altho it is fiberglass. Any hints?
Thanks....
Ed
Old 09-21-2004 | 07:32 PM
MinnFlyer's Avatar
Default RE: GP Cub arf refueling
Fuel dots are the way to go. Just use a third line from the tank. that line should go to the bottom of the tank for De-Fueling.
If you don't want to run it through the cowl, you can just locate it on the side of the fuse.
Old 09-21-2004 | 08:15 PM
Thanks for the quick reply and the drawings. Made it easy to understand. Had a couple of more questions. Looking at the 3 line setup it looks like as the tank fills and the fuel level rises, will the fuel get to the carb and maybe flood the engine? Also, I'm going to use a 4 stroke and will try to turn the header in so that the muffler will be hidden in the cowl. I'll have to open the bottom and maybe put on an extension to the muffler. I guess with a setup like that the only way I will know that the tank is full is when the fuel drips from the muffler. is that correct or is there another way? Lastly, I found one web site, Central Hobbies, to look at fuel dots. Do you know of any other web sites that I can look around for the fuel dots? Any brand you have had luck with? Thanks again, Mike, for all your help....
Ed
Old 09-21-2004 | 09:31 PM
My Feedback: (24)
Hi,
I just put a Dubro refueling fitting on the bottom of the fuselage near the edge of the firewall and made an opening in the bottom of the cowl. I also added some epoxy around the area to give it a little more strength. I have had it on for over a month now with no problems.
Take care,
Matt
Old 09-21-2004 | 10:49 PM
crashland 73's Avatar
My Feedback: (24)
i have one of those super fuelers, black plastic things. I have quite a few and they work good.
Old 09-21-2004 | 11:35 PM
Fletch124's Avatar
My Feedback: (7)
here you go it would look super cool on a cub. GO TO FUEL VALVES. http://www.towerhobbies.com/listings/cat-cat-p2.html
Old 09-22-2004 | 06:34 AM
MinnFlyer's Avatar
Fuel will not flood your carb. The pressure will always take the path of least resistence, which in this case is the air vent. Some fuel may get all the way to the carb, but only enough to prime it. And yes, with the muffler inside the cowl, you'll have to wait for the fuel to come out of it.
I prefer Fuel Dots over "Filler Valves" mainly because filler valves are prone to leaks, but also because it never fails that I will lose that stupid little probe that is the only thing you can use to fill it with.
Old 09-22-2004 | 03:00 PM
Thanks for all the great ideas. Should be easy to decide with all the options you guys gave me
Ed
Old 09-22-2004 | 03:27 PM
piper_chuck's Avatar
My Feedback: (12)
One of my planes has the Dubro valve in it. Works great. The only thing I don't like is the extra plumbing inside the cowl. It can be a bit awkward to reconnect when putting the cowl back on. I've got another plane with the three line setup. So far, I like that better. What I like best is that there is a more direct path between the tank and engine. Less chance of something plugging up or a fuel line falling off. I didn't bother with a fuel dot, just left the fuel line hanging out the bottom rear of the cowl a bit. I plug it with a screw. Can't get much simpler.
Old 09-22-2004 | 04:22 PM
rslstft's Avatar
My Feedback: (10)
Techsarge,
I have 2 GP Cubs, both with 4 stroke engines. I use PSP Manufacturing's fuel dots. (www.PSPMFG.com) They come in 2 sizes and in different colors. I never have any problem with flooding the engine and it's easy to de-fuel with them also. I use a second line and clunk in the tank for the 3 (fill) line, but that is just my personal preference.
Russ
Old 09-23-2004 | 04:15 AM
Piper-Chuck and rslstft...
Thanks for your ideas and sure appeciate the feedback. I'm kinda anxious to get the cub finished and up in the air before the wx gets rough...
ED
Old 09-23-2004 | 11:06 AM
ptgarcia's Avatar
My Feedback: (36)
I bought a bunch of the PSP Manufacturing fuel dots and I really like them. And the anodized finish is sweet!
Old 09-23-2004 | 03:48 PM
Hi...
I just walked in the door after I stopped at my LHS. THe only brand they had today was RC City and I settled for that. Appreciate your suggestion and the anodized metal sure looks good...
Ed
Old 09-24-2004 | 02:50 AM
forestroke's Avatar
Just a word of precaution, although it is true that fuel should always take the path of least resistance, it is still good to be careful. I always close my needle valve when I fuel if I am fueling through the fuel dot on a three line setup. Just makes me feel more safe. Also, prevents fuel from sitting in the glow plug and fouling it up!
Old 09-24-2004 | 02:46 PM
My Feedback: (21)
you know.. I was just thinking about this.. and if you used a 3rd line to the fuel tank and used a fuel dot, you could carve some balsa in the shape of the full scale's tank cap with the fuel level wire and glue it on top of the dot..just to make it look better Just an idea.. I'm going to have to do that on my cub if I ever get around to building it
Old 09-24-2004 | 02:50 PM
My Feedback: (24)
That sounds like a great idea. I might do that sometime. I have FINNALY gotten to fly 2 times this week, first time in quite a while. The wind has been really bad. I wonder if anyone flew during the huricane down at florida?
Old 09-24-2004 | 07:31 PM
Thanks to all...
Ed
