 hanger (  mentor engine size >
Old 09-26-2004 | 12:04 PM
My Feedback: (22)
Default hanger ( mentor engine size
the hanger 9 calls for a ,40 to .58 2 stroke,,
I want to use my older sk supertiger 61 to fly it..it will employ retacts and mfg.states flying weight of 6 to 7 pounds..will I be overpowering it to an exteme..???the article in model plane shows a 4 stroke 70..I would rather not have to purchase four stroke..one last thought I do have a unsed new older fs 9o..was going to sell it but it might work too..help
Old 09-26-2004 | 02:30 PM
My Feedback: (24)
Default RE: hanger ( mentor engine size
i hate two strokes for 3d or scale but don't put that 90 on it way to heavy the 61 will be fine i fly a saito 72 and cg came out fine
and is there a overpowered extreme
Old 09-26-2004 | 09:04 PM
My Feedback: (22)
thanks..the os 90 is an older version so I magined it slow,but your right ..I actually just want to put my reliable supertiger on it but I could be persuaded to do a four stroke 70 or satio 82..
Old 09-27-2004 | 08:25 AM
CAPT John's Avatar
My Feedback: (15)
I have a OS 50 2 stroke on my Mentor. With retracts it weighs in at just over 7 lbs. I would like to have more power for takeoff, but once she's airborne with the gear retracted, the plane is very fast. I think your Super Tiger 60 will be a great combo.
Old 09-27-2004 | 08:59 AM
I had retracts on mine with a Magnum 46 XL, and It flew very scale like. Takeoff from grass was a little difficult with the small wheels. The 61 would work in it just fine, but you may find that you need to use a pitts style muffler instead of the standard one. You'll have fun with this plane, good luck
Old 09-28-2004 | 11:45 AM
My Feedback: (22)
thanks guys..I sort of figured the 60 would be okay with retracts..I am not looking to burn up the sky but I want to punch it when going vertical or just make the aerobatics a bit faster..I certainly like 4 strokes but I want to utlize what I have currently in inventory..can I ask what mfg. retracts you guys used???? oh and I have an older and reliable running enya 60 too and I plan to use a pitt style muffler to keep the cowl scale......
Old 09-28-2004 | 03:48 PM
CAPT John's Avatar
My Feedback: (15)
I am using the Hobbico .40 size retracts in my Mentor. Initially I had lots of problems, but I finally decided to use JB weld to keep the wheel/axles from turning on the struts, and now the retracts appear solid on the grass runway.
Old 01-03-2005 | 12:33 PM
do you think a saito 80 is overpowering for the t 34
Old 01-03-2005 | 12:55 PM
My Feedback: (24)
no
