Question to all Ryan STA owners please >
Old 08-07-2002 | 11:00 AM
Default Question to all Ryan STA owners please
I heard a special servo reverser is needed for this plane.
I own a digital 8 channel programable radio.
Can the radio just make the reverse or I still need to buy the special device to reverse servos????
Old 08-07-2002 | 11:57 AM
Most likely Depends on your reciever...
Old 08-07-2002 | 01:28 PM
Blackie's Avatar
Depending on what radio you have it can be done. I happen to have the Eclipse 7 which will do it with some configuration but if I am not mistaking I am only limited to trimming the master channel. If you have a futaba or JR 8 channel I believe it can be done. I elected to use the servo reverser.
Randy
Old 08-07-2002 | 01:39 PM
Its the usual reciever that comes standard with the Futaba 8 channel radio
Old 08-07-2002 | 01:42 PM
ok and what is it that the servo reverser for?......elevator?
can u mix the 1 elevator servo to aux 1?
Old 08-07-2002 | 02:05 PM
Blackie's Avatar
T28, I can answer this for Motoadve, yes its for the elevator, I am assuming that his radio is the 8 channel Futaba and if so I believe it is capable of trimming both channels aux and master.
Motoadve try posting the mixing question under the radio section on this forum. There is a thread specially made for Futaba questions depending yours is a fataba.
Old 08-07-2002 | 02:22 PM
thanks blackie.....i don't have a futaba but i imagine its like my JR
Old 08-08-2002 | 01:27 AM
You plug one elevator servo into the elevator channel and the other elevator servo into an auxiliary channel. (you need at least a 5 channel receiver) Then you mix the two channels (elev and aux) at 100 percent and reverse the servo in the auxiliary slot....simple! The transmitter does all the work...your receiver just takes the orders and has no idea the aux channel is driving your other elevator half. Your manual should explain this.
Yak
Old 08-09-2002 | 01:44 AM
Flyboy Dave's Avatar
My Feedback: (21)
Default Motoadve
Plug one elev. servo into ch-2.....plug the other one into ch-5 (the retract channel).
Then..."slave" ch-5 to ch-2...then use the servo reversing, ATV throws, and such as necessary.
Dave.
