 h9 edge 540 engine help >
Old 10-21-2004 | 12:24 AM
Default h9 edge 540 engine help
hi i have the h9 120. edge 540 i need help i have a saito 182t twin would this be a good engine in this plane. will this be enough power.thanks
Old 10-21-2004 | 03:58 AM
My Feedback: (172)
Default RE: h9 edge 540 engine help
I don't know much about the Saito twin you have, but compare it to the 180 single. I had a H9 Edge with a Saito 180 and it flys great!
If the twin is alot heavier I might steer away from that engine. I'am turning a 16 x 8 at around 9400, and my plane weighs about
11.5 lbs. You can use that to compare what you have. It has almost unlimited verticle, and yes it will hover, even though I'm terrible at that.
Rick
