 4 * 60 throttle link >
Old 11-13-2004 | 01:12 PM
Banned
Default 4 * 60 throttle link
The link that comes with the 4 * 60 for the throttle is very weak and bends when the servo tries to move the throttle of my TS91 . So basicly what i need is another medium for connecting the throttle servo with the throttle, that wont bend... Any ideas?
Old 11-13-2004 | 02:20 PM
Banned
Default RE: 4 * 60 throttle link
thx for all the help
Old 11-13-2004 | 04:07 PM
I used the original link (wire and tube) which came with the KIT. I guess the ends of the link need to be attached to the fuse for it to work properly. I have a Saito 100 inverted in mine and absolutely no problems with the link.
When I say the ends of the link I mean the tube.
--kaboomski;
Old 11-13-2004 | 04:17 PM
I used a throttle cable instead of a pushrod set-up. The cable has worked so far as it is sturdy enough. I also used E-Z connectors both on the servo and the throttle control horn. I wanted to use the E-Z connectors on both ends, but the pushrod I had was too small in diameter, thus I wasn't able to tighten down the screws on the connectors. Using a thicker, threaded type cable allowed me to do so. Probably an unconventional way, but the cable is sturdy enough, and after several flights it has worked fine. I have an os 90 fx on my 4 star 60.
Joe
Old 11-13-2004 | 06:09 PM
Banned
Ok, im glad the original link (wire and tube) which came with the KIT worked for you, however, not for me. So i need another way to do this.
Old 11-13-2004 | 06:17 PM
rajul's Avatar
Moderator
My Feedback: (58)
You need to solder and file the ends of the cables. Was that already done in the arf, or any instructions on that in the manual ?
Old 11-13-2004 | 06:59 PM
Banned
Yes, i did that, i soldered them and got it to work, but the problem is it is too weak to move my engine's throttle...
Old 11-13-2004 | 07:03 PM
Banned
it BENDS
Old 11-13-2004 | 07:18 PM
rajul's Avatar
Moderator
My Feedback: (58)
See if this excerpt from the SIG manual is helpful.
Old 11-13-2004 | 07:35 PM
Banned
Although my instructions dont have that page with the pictures, that is exactly what i did, even some sort of "support block" which wasnt in my instructions...
It works fine when the engine is cool, but once it gets hot it gets a little stuck and its too much for the link... I need something stronger...
Old 11-13-2004 | 07:39 PM
Banned
Now that i look at it closer, that is not the link that came with mine. Its ALL bendable, not a bit of nylon tubing. Unlike that one in that picture which has nylon tubing:
Mine is like this:
Old 11-13-2004 | 09:14 PM
Banned
I must fix this :/ i wana fly it soon.
Old 11-14-2004 | 02:57 AM
My Feedback: (41)
There should be some tubing that it was supposed to go into. It doesn't come installed in the tubing. You install the tubing, then the flexible cable after soldering ends to stiffen, then attach connectors and connect to servos. It will not work without that tubing to keep it stiff.
That's waht the leftover piece of tubing is for!
