Texas Hurricane >
Texas Hurricane
Texas Hurricane
Old 09-18-2002 | 01:45 PM
Yakdude's Avatar
Default Texas Hurricane
Hello,
I am considering purchasing a Super Kraft Texas Hurricane as my next project. I understand the newer versions are a different color scheme than the one on there website. Does any body have any pictures.
The plane looks kind of ugly on the website.
I have heard nothing but good about the construction and overall quality of this arf.
I am thinking of powering it with a Taurus 52.
Any comments please.
Lenny.
Old 09-18-2002 | 02:23 PM
My Feedback: (13)
I had an opportunity to check the airplane out thoroughly at Toledo, and it looked to be very well constructed. I did not buy one, but only because I already have several similar planes. Also one of our club members has one, and flies it regularly. He is very satisfied w/it. He flies it in IMAC contests, and has placed well in the contests. Based on my limited exposure to the model I would recommend it. My only reservation to the plane is that it seems a little "pricey" for it's size.
Old 09-18-2002 | 03:22 PM
BAS
My Feedback: (28)
I jhave the older version i got it this past spring and i have a fpe 2.4 .The Taurus 52 would fly it very well as that is what i am putting in my next Hurricane i allready have the motor purchased. I havent really seen the new version up close there is picture of it somewhere on this arf section under the model show in Chicago i believe. I love the quality of this plane and for what you get its a good deal > They are selling them for around 380 or 390 and for what you get its a good deal. Some of the hardware i didnt use .. With that motor combo i would put rudder servo in the rear fuse for balance and its a breeze to hook up that way. I had to add around 13ozs of lead to balance mine but that is with the 2.4 up front which only weighs around 3 and 1/4 lbs. Good luck
Old 09-18-2002 | 04:05 PM
I have the same one as Bas and agree with everything he said. Mine has a Brison 2.4 and its performance is outstanding. I ordered the new one and I'm putting a Brison 3.2 in it, as my son has taken over the old one. The new trim scheme is much better looking than the old and I can see the battle comming between us as to who gets the new one {a battle I will win.........yea right}. ;^}
Old 09-18-2002 | 04:20 PM
Yakdude's Avatar
Thanks for the fast responses.
One question I forgot to ask. Does it have a 1 or 2 piece wing?.
Lenny.
Old 09-18-2002 | 04:28 PM
BAS
My Feedback: (28)
Two piece wing plug in alum tube wing bolts allready installed
Old 09-18-2002 | 10:03 PM
The new Kangke Texas Hurricane will be like the one reviewed in Flying Models March 2001 including the tail assemble.
Old 09-18-2002 | 10:16 PM
Yakdude's Avatar
Great,
I will purchase one soon. Anybody know a good dealer for Kangke.
Lenny.
Old 09-18-2002 | 10:39 PM
BAS
My Feedback: (28)
www.BoltonSales.com right around 390 for new color scheme plus shipping 390 shipped on the old color scheme
Old 09-18-2002 | 11:01 PM
Cyclic Hardover's Avatar
For $400 you could probably do alot better on a NIB arf on this site or Ebay. Also those bars which hold the wing on. two of them here were off a bit
Old 09-18-2002 | 11:07 PM
BAS
My Feedback: (28)
What do you mean by bars that hold wing on the Hurricane is held on with alum wing tubes and bolts that bolt in to wing root On my first flight i didnt have to put any trim imput at all
Old 09-19-2002 | 12:21 AM
What bars? I think you have the wrong plane in mind. Bas is correct,alum tube with lock bolts through the fuse side. Mine only needed elevator trim on its first flight.
Old 09-19-2002 | 08:08 AM
My Feedback: (13)
Well Mr. BAS and Mr. Outcast,you can add Jimmy Bananas to the list of "Hurricane Lovers"..Getting mine next month.,.FPE 2.4 going in it..BTW,is the picture of the Hurricane in this posting, is that the new paint scheme?..If so, will get the 'Newer " one...
Old 09-19-2002 | 08:32 AM
Default Me Too!!!!
You can count me in also, as being a Hurricane fan. A great 2.4 ARF all around. I may even order the new color scheme, just because............
Old 09-19-2002 | 09:22 AM
Bananas, yes the photo is the new trim scheme, and mine arrived yesterday. The photo doesn't do it justice.
Old 09-19-2002 | 02:07 PM
My Feedback: (13)
Chief Aircraft has a picture of the new color scheme:
http://www.chiefaircraft.com/Models/Model.html
Old 09-19-2002 | 06:06 PM
epc's Avatar
epc
My Feedback: (33)
A couple of questions for the Texas owners:
Is the tail removable?
Is the leading edge completely straight like the edge?
Does the plane have a hatch for easy access on those rear induction carb engines and for ignition etc?
Thanks in advance
epc.
Old 09-19-2002 | 07:04 PM
epc, the answers to your questions are yes, yes, and yes. Although I'm not sure how far the carb would stick through the firewall, it would depend on which rear iduction engine you have in mind. :^}
Old 09-19-2002 | 07:44 PM
My Feedback: (10)
Ok,So your telling me that if I Stick my Brison 2.4 in this plane it will have unlimited vert?With authority?I keep hearing so many things about this plane but want real world results.Will a taurus 3.2 or brison 3.2 be a better choice?I don't want to rip the wings off this thing but need to know if a 2.4 is enough.i hav 2 of these engines with no home right now.I need enough power for good 3d without the weight penalty.
thanks guys!
Old 09-19-2002 | 08:58 PM
poolguru, My hurricane with a Brison 2.4, Bisson muffler and 20/8 Pro zinger has by any-bodies definition unlimited vertical. It will accelerate straight up from a hover till it disappears in the clouds. A Brison 3.2 in my opinion is the absolute limit in power that could be used, you cant fit a prop bigger than 22-inches.
Old 09-19-2002 | 10:16 PM
BAS
My Feedback: (28)
My fpe 2.4 wont go unlimited vertical but engine is still breaking in gets stronger every time i take it out i think a 3.2 would be ideal but like outcast says you have the ground clearance limit to worry about i also run pro zinger 20/8 prop. By the way out cast Jimmy Banasas ordered the hurricane from Chief aircraft check the price 369 shipped wow what a deal
Old 09-19-2002 | 11:04 PM
I know he sent me an e-mail, If he likes the Laser he's gonna love the Hurricane and $369 is a real good price. :^) Also my Brison is a mechanical advance engine and I found it makes more power with about 4 degrees more timing than it came with. you may want to try that after its broken in.
Old 09-19-2002 | 11:44 PM
Yeh those things. two of those planes here were returned by the same guy. One of those tubes were about a 1/2 inch off. Gives the impression the ass end is twidted but its the bar/tube
Old 09-21-2002 | 11:22 PM
Bryant330L's Avatar
My Feedback: (126)
Hey guys,
I looked at the Chief site and it did not even list any Kangke products. I did a search and nothing turned up.... I want a better look at this new scheme. I liked the shape of this plane all along but I did not like the old covering. I have a Sachs 3.1 that sounds like it would be great in this plane. What do you guys think? I would probably get it for $369 if I could find it. Thanks for your help. Anywhere else I could see the new scheme besides the chief site?
Old 09-21-2002 | 11:43 PM
My Feedback: (10)
When the page comes up click on WHATS NEW.
it will be thier.....SWEET!
