 GSP Giles 202 >
GSP Giles 202
GSP Giles 202
Old 10-31-2005 | 04:49 PM
  #51
Pete850's Avatar
Default RE: GSP Giles 202
Hi Jan,
I'm afraid it looks like your wing tube location in the fuselage was incorrectly jigged at the factory setting in at a slight angle across the fuzz. Mine fits perfectly.
I'd suggest you ask for a replacement fuselage. Hope you haven't put too much work in it yet.
You won't regret this choice of plane - they are superb fliers.
Old 11-01-2005 | 05:09 PM
  #52
jho
Hi Pete,
I called the dealer the other day and told him about the building flaw in my kit. He said this would be rather “normal allowance†in production and should neither harm the stability of the wing tube nor the flying performance. He however advised me to contact the importer Jamara which I didn’t. I was a bit tired of argueing with him.
In the end I loosened the outer tube from the fuselage, widened one of the holes in the fuselage a bit moved the tube a little backwards and the wing fit perfectly.
I will power mine with a Webra 120 with pump on a 16x8 apc prop. Let’s see how this turn’s out to be.
Old 11-02-2005 | 08:38 AM
  #53
Pete850's Avatar
Hi Jan,
Glad you got your wing fit sorted. I certainly wouldn't call a 4mm gap normal allowance, but then I'm an engineer.
You're going to love this plane. Not sure if you've got enough engine though. Correct me if I'm wrong here chaps, but I think you really need a minimum of 1.60 to release the true potential of this plane.
Old 11-03-2005 | 04:15 PM
  #54
jho
Hi Pete,
I will give it a try with the 1.20 Webra. If not sufficient I can look for a OS 1.60 or MVVS 1.60. I think if I can keep the Giles' weight w/o fuel somewhere at 4900 grams the 120 should be fine for normal aerobatics. Definetely not enough for some 3D maneouvres, I agree.
Are you satisfied with the MVVS 1.60 methanol engine? It is quire cheap over here (160 EUR). I used to have the 0.60 and 0.91 MVVS engines and I had some problems to tune the carb to have the engine run reliably. So many deadsticks, but it became better when fully broken-in. Maybe my fault but when you are used to user friendly OS engines and carburettors MVVS can be a challenge.
Rgds Jan
Old 11-04-2005 | 03:37 AM
  #55
Pete850's Avatar
Hi Jan,
I am very satisfied with my MVVS 1.60. It starts easily and has been totally reliable in 25 flights. I have had no problems with tuning. I don't think it has quite the power of the OS, (7300 with an 18x8 and Bisson pits silencer) but at half the price I'm not complaining. Of course this could be due to the fact that it runs on straight or 5% fuel too.
Old 11-04-2005 | 05:46 PM
  #56
My Feedback: (12)
I was just at the LHS here in Germany and was told they had a few guys break the fiberglass wing tube and were offering aluminum ones to replace it with. Anyone heard this?
Jeff
Old 11-04-2005 | 08:54 PM
  #57
Zippi's Avatar
My Feedback: (10)
ORIGINAL: Pete850
Hi Jan,
Where are you guys buying this ARF? I don't see the green plane listed on GSP website.
Old 11-05-2005 | 03:15 AM
  #58
Pete850's Avatar
I got my green version is from Flair Models in the UK, but don't know where you guys get them in the States.
Old 11-06-2005 | 11:12 AM
  #59
AQA's Avatar
AQA
Hello.
This one is from Slovenia.
Firs flight....
Engine Mvvs 26ccm ifs gas
Old 11-06-2005 | 01:51 PM
  #60
Pete850's Avatar
Hi AQA,
Welcome to the forum.
So how did the first flight go?
What prop are you using with your MVVS and what revs are you getting?
Old 11-06-2005 | 02:39 PM
  #61
AQA's Avatar
AQA
I am using Metts prop 18x8.....it gives me 7,8 kg of thrust with long mvvs exhaust.
Old 11-06-2005 | 02:43 PM
  #62
AQA's Avatar
AQA
First flight is always a problem, but it went well. Landing is very smooth.
Old 11-06-2005 | 02:57 PM
  #63
AQA's Avatar
AQA
Try this link......i introducet this model on our forum.
http://forum.modelarji.com/viewtopic.php?t=6915
Old 11-07-2005 | 01:19 AM
  #64
I originally called the thread GSP Giles and cant modify it..later I found out that it is most likely built by china model productions cmpro
ORIGINAL: Zippi
ORIGINAL: Pete850
Hi Jan,
Old 11-07-2005 | 06:18 AM
  #65
Pete850's Avatar
Hi AQA,
Went on your forum - some good build pics, but I haven't a clue what you're all talking about!!
Old 11-07-2005 | 11:17 AM
  #66
AQA's Avatar
AQA
ORIGINAL: nitro wing
ORIGINAL: Zippi
ORIGINAL: Pete850
Hi Jan,
http://www.lindinger.at/
http://shop.lindinger.at/ProductTree...6&PPP=20&SP=20
http://shop.lindinger.at/ProductDeta...3D20%26SP%3D20
This model is made in China 100%
Old 11-08-2005 | 02:16 AM
  #67
I am wanting to purchase this Gile also. How is the instruction manual? Is it reasonably descriptive with photos etc? Thanks for any input!!
Joe
Old 11-09-2005 | 12:56 AM
  #68
it is one large sheet with a very detailed drawing,if you study it carefully and ask a few questions here,you should be able to get through it,without much fuss.
Old 11-09-2005 | 01:07 AM
  #69
thanks Nitro
Old 11-10-2005 | 10:30 AM
  #70
Hi AQA,
How much it weighs from this engine???
Darek
Old 11-13-2005 | 03:37 AM
  #71
AQA's Avatar
AQA
Hello.
...5,4 kg without gas
Old 11-13-2005 | 03:44 AM
  #72
Pete850's Avatar
Hi Darek,
Mine's 11.5lbs dry
Old 11-13-2005 | 06:27 AM
  #73
AQA's Avatar
AQA
Paste some more pictures
Old 11-13-2005 | 06:32 AM
  #74
Thanks guys
I think so[8D]
Old 11-13-2005 | 06:35 AM
  #75
Yes, yes
