Great Planes SpaceWalker Help >
Old 11-11-2002 | 07:50 PM
Default Great Planes SpaceWalker Help
I'm sure this was not a good choice, for my first plane, but I have everything together now, but having problems, with getting the screws on the wheel pant bracket's, and wheel collar's, to tighten enough around the axel to hold firmly in place. Any suggestions on this, and any other advice would be appreciated.
Old 11-11-2002 | 08:08 PM
I would just leave the weel pants off. There more trouble then they are worth, can always put them on after.
The gp spacewalker is an easy plane to learn to fly. Lands easier than a trainer. I tought someone to fly and they landed on there first approach, after practicing on real flight g2
Old 11-12-2002 | 02:26 AM
Default landing gear problem
Forget the stock landing gear and install a 4- Star 120 landing gear on the front of the fuselage.
Old 11-15-2002 | 10:10 PM
Default Wheel pants
I agree that pants can be a pain in the butt yet they look great. You must "flat-spot" the axle. Use a Dremel or ******* file to faltten the axle at the location where the set screw goes. This flat spot will prevent the screw from rotating around...along with the wheel pant.
My SW died in a mid-air about 6 flights into it. It was a beautiful flying plane and agree with the other comments on its handling. Three points landings are a breeze.
Old 11-15-2002 | 11:23 PM
trailingedge's Avatar
I have a friend who bought a spacewalker and was terribly mad b/c it flew like a trainer. Hehe I guess he should have done a little asking before buying *lol*. craigshortcut, you shouldn't have any trouble with this plane although I would recommend an instructor be nearby.
Old 11-16-2002 | 07:29 AM
GoeKeli's Avatar
My Feedback: (18)
Your gonna love this plane. Get some help.
Just find the right pilot and you'll be fine!
HTH
Joe
Old 11-16-2002 | 08:41 AM
gene375's Avatar
Default spacewalker
i have had the same problems with my wheel pants, tried the flat spots, but grass landing are not kind, i have recently removed them, I still use the supplied landing gear, no problems, I have an OS91 fs, It is a gentle giant....the envy of the field, looks great on a nice sunny day in the air..
Old 11-18-2002 | 01:22 AM
Banned
Wheel pants- got to have them!!!
Replace the GP hardware on the wheel pants with SIG's version, they look about the same, but are much stronger, and have a bigger screw, mine have never come loose. I have also installed SIG's fake engines on my cowl.
Old 11-18-2002 | 06:39 PM
Thanks everybody for all the advice. I ended up fileing the flat spot,and also used cap screws. Also put 3 1/2" wheels instead of the 2 1/2". Everything seemed to tighten up fine. Of course I haven't flown yet. Please send any more comments on the SW,need all the help I can get.
Old 11-18-2002 | 08:37 PM
Default Wheel Pants
Don't forget the Thread Lock on those screws. I, too, replace them with cap heads and I almost always use the SIG hardware. It is simply better stuff.
Best of luck and remember...bigger will look much different on final so keep the power on and don't let it stall.
