H9 1/4 scale CAP 232 engine thrust angle >
Old 11-21-2002 | 05:14 AM
My Feedback: (18)
Default H9 1/4 scale CAP 232 engine thrust angle
Hello,
I have taken the suggestion to use the cowling as a guide in mounting the ST 3000 inverted on my CAP. Much to my surpise it was very fast an easy and I now have the holes marked for the engine mount.
Since I am using this large engine and will be using a large prop, 18X10 - 20X6, I was wondering if I should shift the egine left and add some right thrust. How much, if any, right thrust are others adding to their CAPs?
TIA for your help.
Old 11-21-2002 | 11:39 AM
My Feedback: (20)
Hey GalenB
This plane has the thrust built into the fire wall already!
Doug
Old 11-22-2002 | 04:33 AM
My Feedback: (18)
Doh!! You are right!! Once I put a triangle against the fuse side it was obvious... Thanks!
