Top Flite Staggerwing
#601
My Feedback: (23)
GA
RE: Top Flite Staggerwing
ORIGINAL: Tall Texan
Paul,
Where did you insatll your switches? I assume on the botton of the plane.
Paul,
#602
I plan on putting the BGX-1 3500 on my Staggerwing. Has anyone tried this combo? I have the plane together and the weight should be about right. Wondering about performance. I am also thinking about reshaping the flaps to a four aileron set up with flaperons. Your input would be greatly appreciated. Jim
#603
VA
Why would you want to convert the separate flaps and ailerons to four "flaperons"on both top and bottom wings? Leaving aside that wasn't/isn't the way full scale Staghgerwings are set up, what are the advantages you see?
My Feedback: (23)
GA
ORIGINAL: flaviosi
Hi, GGGB
Very cool switch!! Where did you buy it?
Flavio
Hi, GGGB
Flavio
http://www.maxxprod.com/
#607
My Feedback: (23)
GA
ORIGINAL: dirtydingus
Forgive the dumb question... I'm not at all familiar with the BGX-1 3500. What is its four stroke glow or gasoline engine equivalent?
#608
I have talked to a couple of past staggerwing owners who both agreed, "unless you are going flat out, the roll rate is anything but brisk". I'm not looking to turn it into a pitts, just want to wake it up a bit. The BGX is a big OS two stroke. With a little more power than the 1.60 and the extra weight needed up front.
#609
VA
That's an interesting-sounding engine. I've got an OS 1.60 in my RC Guys Super decathelon that I'm getting ready to maiden, and probably'll need some weight on the nose.
Does it have its own website, or is it on the OS website?
#611
My Feedback: (67)
ORIGINAL: GaGeeBees
The Rx switch is located up under the top wing. It's not invisible but it's not at all noticeable.
Paul,
Paul,
Never thought of putting it up under the top wing. Good idea. Mine was thin enough i put it right on one of the black stripes on the side of the fuse. The charge jack is integral with the switch. Air fill is underneath the fuse.
#612
I tried to find my answer in this looong post, but could not find the information.
What is the inner diameter of the cowling where the cylinders approx are?
#614
My Feedback: (23)
GA
ORIGINAL: affas
ORIGINAL: affas
Nobody that can help me with the diameter?
Very difficult to measure. I will take my cowling off and see if I can get you a dimension.
#615
affas,
I don't have the TF Staggerwing, but it is approximately 1/5.3 scale and the TF 1/5th Dummy Engine can be used. Its trimed to fit size is approximately 8-1/2"(21.5 cm). The Saito 160 twin also fits with in the cowl without cut outs since you did not specify which cylinder (Dummy or actual power plant) location. The cowl gets wider from front to back and at the Dummy Engine location the inside diameter should be approx. 8-1/2" and gets bigger towards the rear.
#616
Has anyone done one of these with a gas engine? I have an SPE 26cc engine in mine and man is it nose heavy. It's taking about 3 pounds 2 ounces to get the balance correct using a Great Planes C.G. Machine, according to the instructions (5 1/2" back from LE of lower wing) . That's with the weight behing the tail wheel, so I imagine I'd have to mount it just inside the tail cone. I'm worried that much weight at the tail would cause problems for the tail wheel retract. Moving the batteries would hep some, but I don't think it would help a lot.
Any thoughts?
-Jorden
Any thoughts?
-Jorden
#617
WA
I put a 40 cc Brissen in mine. It is completely hidden except for some small areas around the muffler but you can only see these spots from directly underneath. The spark plug boot also shows but since I mounted the engine with the cylinder point down, and the plug angles back, only small amount shows and again, only can be seen from below. The big work I had to do was to modify the fire wall to accept the pitts muffler. The engine fit nicely but the round muffler cut into the fire wall about an inch. The mod cannot be be seen with the cowl on and I did such a nice job it is almost a shame, lol..
First I calc'd the location, then I dremeled out the existing firewall to approxamate size. I then took a 3" piece of pipe, wrapped in with course and paper and complted the relief so it was a perfect quarter circle. I beefed up the structure to make up for removing some of the fire wall then, I used the same pipe, wrapped in wax paper and made a fiberglass filler. Once cured, it fit exactly against the cut out. I carefully trimmed the oversize piece, then used epoxy with microballons to attach it from the inside. The final piece was fine sanded and painte to match. The result is a custom pocket for the muffler to recess into and looks like factory. It was definately worth the work of which took me 4 evenings to complete.
#618
My Feedback: (62)
UT
ORIGINAL: bluestratos
#619
WA
No, I had to add a couple of ounces to the firewall. I have the batteries and ignition box mounted on the false fire wall I made to extend the engine.
#620
My Feedback: (13)
OH
Ive been running a OS BGX in a 80" extra for the last two years, and it has been a GREAT engine. Its comparable to a moki 2.1, runs on regular nitro glow fuel (mokis like 0%) and hasnt given me any trouble. When the BGX came out years ago, some people had problems with it, probably because they tried to run it like a moki. If you plumb it with large tubing and fuel line, you will be very pleased with this engine in any application, its a brute! Also, do yourself a favor and put a bisson muffler on it, the stock muffler is a power robber.
My stag is sitting patiently in its box, awaiting its turn on the table. Ive got the saito 220 for this bird, cant wait to get working on it!
so many projects.......so little time.....
Ted
Ted
#622
Hi, TeamScale!
I have a Fuji 32 EI engine and I'm wondering if it would fit well in there. Do you have some pics of the interior of your cowl?
Thanks in advance!
Flavio
Power Fugi 24 gas.
Thanks in advance!
Flavio
#625
MN
ORIGINAL: teamscalepilot
Finally flew mine today. Power Fugi 24 gas. Very stable aircraft!!! As you can see how I transport it to the field. We are a mile from the sod farm!!
Looks fantastic!!
Justin
