LITTLE HELP WITH MY U-CAN-DO 3D 60
I have just beginned to build my U-CAN-DO-3D 60 , but I have a problem :
The instruction sheet says that the line marked on the firewall are not center , but a little left-aligned ( this is for right thrust ) , I expected that the firewall itself was mounted with a little angle , so that the prop would be exactly in the center line , BUT THE FIREWALL IS ABSOLUTELY AT A 90 DEGREE WITH THE FUSE !.
If I mount the engine following the marked lines I am sure that it will not have right thrust , it will be parallel with the fuse BUT MISALIGNED !
Is it normal ? I think no ; anybody else has found this problem ? , and which way arranged it ?
The istruction sheet says nothing about putting washers between firewall and engine mount , but I think I will do.
What amount of right and down thrust do you have in your UCD?
Every help or opinion will be greatly apreciated.
THANK YOU
THANK YOU
