Fliton Rogue 3d.. but with glow..
OH
RE: Fliton Rogue 3d.. but with glow..
I have a mini 3D with a 25 FP on it and it is great and it is a super light plane as well. I think it wold work well on one of these. I need to find one and give it a try.
Chris
Chris
IN
i guess the other post for the rogue is strictly electric, no comments from them. anyway, i built mine with a magnum 30 four stroke and even with that engine i still needed the battery pack up on the firewall. sneaking in the gas tank was fun but effective. the magnum flies this unit well with a 9x6 prop but no quite in a hover,,,,,,,,,,the 10x4 prop flies it well but boggs the engine. maybe 20% nitro is next.
maybe the 25 two stoke would do the trick, any one try one yet
OH
I have an old OS 28 That I am going to try in this thing as soon as I save up a few bucks. It is the same size as a 25 just stroked out a bit. I was wondering what servos and reciever did you use in yours. I need to know what Ineed to get as far as electroonics to fly this bird well.
Chris
Chris
My Feedback: (13)
1 Post
What are you using for receicers, servos and the battery pack? Nitro plane stuff or featherweight electric stuff with just a nicad battery??????
i have also converted an e-flite edge 540 to glow with a thunder tiger 15 engine last month, cruise round at half throttle, unlim verticle.
The landing gear is WEAK!! make it stronger before you fly!!
i use HS-55 servos, a 600 mAh hitec battery pack and an Jeti Rex 7 MPD receiver... it works great! right now i'm converting to a OS .25 engine.... interesting to see the difference!
My Feedback: (9)
AZ
I have a little build thread going on a nitro Fliton Rogue if this helps.
[link]http://www.rcuniverse.com/forum/m_4631457/anchors_4787465/mpage_1/key_/anchor/tm.htm#4787465[/link]
