Phoenix Decathlon take off...
AB, CANADA
I have read that some of the other Decathlons are tricky in the ground handlying. Is the Phoenix Super Decathlon tricky as well???[X(]
My Feedback: (180)
RE: Phoenix Decathlon take off...
Yep. It's not a slam to full throttle and yank the stick back kind of take off. My first few attempts were anything but pretty. I was all over the runway before she got airborne.
Slowly add throttle and be easy on the rudder. It actually forces you to learn proper take off techniques.
AB, CANADA
> "It actually forces you to learn proper take off techniques. < OH no!!!!![X(] Just kidding. Hopefully the plane will be ready for this weekend or the next. I think I will be ok.
My Feedback: (13)
ORIGINAL: AllTheGoodNamesAreTaken
Yep. It actually forces you to learn proper take off techniques.
I don't recall hearing this complaint from Goldberg Decathalon owners.
My Feedback: (10)
Both of the comments above are good ones! The fuselage is short coupled and prop torque (P-factor) definitely has an effect. Ditto on the "add throttle slowly and sparingly" comment. Do some high speed taxi runs first and you should get a good lesson and a good laugh out of it. Build plenty of speed before you decide its time to fly or as was said earlier, a snap roll will reward you. The elevator and rudder are extremely effective - remember this! Have fun and give us a report later.
AZ
The Pheonix is pretty mild compared to the Seagull SDC... I use a gyro (I know flak jacket on) on the Seagull DC but don't really need one on the Pheonix... Still takes some practice though... I thought it was the short coupling etc too but a guy in our club just flew the Goldberg SDC and it takes off like a dream ... No problems at all... It seems to be proportionaly the same size... Interesting..
My Feedback: (7)
Ain't that the truth. Must be something to do with the short fuselage; both the GP kit Decathalon and the EZ Models ARF Decathalon (both now out of print, sadly) were the same way. And if you tried to yank it off before it was ready to fly, you were rewarded with a tip stall crash.
[/quote]
Chances are very good that you have never seen a Goldberg Decathlon powered with anything resembling scale power. Last one I saw was trying real hard to be a pylon racer.
AZ
The one I am talkint about had an OS .60 fx in it... Could not believe it got off the ground with that... It flew nice and gentle (scale) .. Being his first flights on it he did not try a loop or anything... I like enough power to at least do a nice big loop in mine..
AB, CANADA
Re: " The one I am talking about had an OS .60 fx in it... Could not believe it got off the ground with that" < so you are saying that an 60 fx is not enough power for a Phoenix Decathlon??
AZ
ORIGINAL: Fastsky
My Feedback: (13)
ORIGINAL: Jim Dines
I spend entirely too much time on here, and can't recall seeing any handling complaints in the several threads on the CG version of the Decathalon. That's what I was saying...
AZ
The Goldberg SDC i am talking about was one sweet flying airplane... It was only the first three flights on it and there were no ploblems at all... It is a lareger plane however with an 80 inch wingspan
My Feedback: (7)
ORIGINAL: Steve Campbell
Actually, the only one I've ever seen was in the box; and, come to think of it, that's where it still is today, in my pal's closet.
ORIGINAL: Jim Dines
My last experience with a 40 size decath was several years ago, using a TT 42GP on a kit built (I don't recall which kit it was). I do recall that flying it required a refresher course in "model airplane flying 101". Had to learn take off all over again, as I could not just hit the throttle and yank it off the ground. Had to actually do a take off roll with a beginning, a middle and rotation. Just like a real airplane.
VA
My 1/4 scale Bud Nosen Citabria was the same way. It just took a while to learn the take tecnique and then you where home free. But buddy you had better not forget your sesson's 'cause it would show how bad your memory got in a hurry. Must be the way of the Citabria....beast....
Pete
Pete
