CMPro Giles 202 - 50
#226
I applied several light coats of Top Flight Clear Coat spray to mine.
Note: remove the canopy before you do this as it will make it slightly opaque.
Let the Clear Coat dry 10-15 minutes between coats, then once you apply a final coat, let the plane dry for a day or two.
Also make sure the plane is CLEAN, and it helps to LIGHTLY buff the existing covering with a PLASTIC dish pad.
Doing so causes the clear coat to adhere better.
#227
I hope this will reach someone who has had one of these planes. I bought one real cheap recently. I have looked all over the web and can not fine one person that talks about where the center of gravity is suppose to be. Yes I can do the normal things with the spar in the wing but was hoping maybe someone could tell me where if should be. Thanks
