Lanier 40 size Mariner
Anybody built and flown the Mariner with a YS63? The suggested engine is a 40 size 2 stroke. The directions indicate that after completion it will still require 4-5 ounces in the nose, since I have just started building I can't check the CG and see if the engine will adversely affect the balance. If you have used the YS63, what prop seemed to work best. Thanks for any information.
