 World Models fuel line >
Old 10-08-2006 | 12:45 AM
Default World Models fuel line
Hey all,
Quick question. Has anyone else had any problems with World Models fuel lines? My problem has been inside the fuel tank, from the clunk to carb. Happened again today, range check, fill tank, start motor, warm up, take off, fly for about three minutes, engine dies, make dead stick landing. This on a Super Sport 40, first time on a Sky raider. Problem is, thin fuel line that splits where you push it on the metal tube. Solution, don't use fuel tubing that comes with fuel tank. This has been the only problem I have had with World Models planes. I have five of them and they are all great flyers. Just thought I'd pass this along, you will know when it happens, cause you can't pump any remaining fuel out of the tank.
Old 10-08-2006 | 02:31 AM
My Feedback: (14)
Default RE: World Models fuel line
ORIGINAL: rcluver
Hey all,
And the funny thing is, the manufacturers appear to think that we do not notice these things....<G>
Something like this can sour a buyer's opinion of a particular brand of product in a hurry.
Fortunately, I seldom use any of the junk that manufacturers provide with their models. I have my old standards that I use with lots of success.
Old 10-12-2006 | 12:19 AM
My Feedback: (72)
I NEVER use the fuel line that comes with ARF's, it's too thin and flexable.
The clunk can actually turn around in the tank.
Old 10-12-2006 | 05:41 AM
MinnFlyer's Avatar
I have had that happen with a different manufacture than WM. Oddly enough, with all of the ARFs I've reviewed, it only happened once - and that was just this past summer - but it happened on a Twin engine plane.
Now I should tell you that I always add a piece of stiff tubing between the tank's plug and the clunk to prevent the clunk from going forward, and the hose split at 3 of the connections in one tank, and one in the other.
Old 10-12-2006 | 10:15 AM
opjose's Avatar
I've have had the tubing that comes with the O.S. engines crack/split TWICE on two new engines.
The first time it was not visible to me and I kept getting deadsticks. The tubing had cracked at the carb but on the inner side so it was not visible or obvious.
As suggested replace the included thin tubing as a standard proceedure.
