 What is P.A glue? >
What is P.A glue?
What is P.A glue?
Old 10-13-2006 | 12:25 AM
Default What is P.A glue?
Thease Chinese manuals use words I don't know. What is P.A glue?
Old 10-13-2006 | 12:28 AM
Sturtz's Avatar
My Feedback: (20)
Default RE: What is P.A glue?
Wonder if they meant to say CA ?
Old 10-13-2006 | 12:33 AM
hehe , mistype... because c and p is right next to each other on the keyboard, but who knows a chinese kb maybe?
Old 10-13-2006 | 01:18 AM
Nope, not a misprint because they have CA glue listed with a different simbol right under the P.A glue. The also call Epoxy A.B. glue
I'ts a Nitro Models ARF.
Old 10-13-2006 | 01:20 AM
Could they mean Polyurathane Adheasive?
Old 10-13-2006 | 03:40 AM
Test005's Avatar
My guess is normal carpenters glue...white glue. (PVA)
Old 10-13-2006 | 03:44 AM
Maudib's Avatar
My Feedback: (51)
If it's a foam model... the Chinese refer to PA glue as the clear to yellowly, sticky, tube stuff they often supply with foam models in a tube. It's light, but longer drying times make it somewhat more difficult to work with. (GWS supplies it with almost model they sell)
It kinda looks and applies like the plastic model cement but is not, as it's foam safe.
I usually use epoxy sparingly in the areas they designate PU glue for... (usually fuse assembly, wing joining, etc)
If this ISN'T a foam model... then what is the application is is calling for? what two components are being glued?
Then we can help you select what glue will best serve...
Old 10-13-2006 | 09:36 AM
Oregon Craig's Avatar
"manuals use words I don't know"
Imagine that!
Old 10-13-2006 | 09:47 AM
Cyclic Hardover's Avatar
Geez, Some guys complain that many manuals are just all pictures, now add this! What's a mother to do?
Old 10-13-2006 | 11:22 AM
It is a balsa model. The manual shows CA uses on most of the hinges but then the P.A is shown applied to the hinge area ( not very clear in the picture ) of the rudder and elevator. It could be the connector wire of the stabalizer halves and the tail wheel where it connects to the rudder. Looking again it looks like they want it on the tail hinges but on the wings they use C.A.
I guess I'm not going to worry about the manual and use C.A on the hinges and epoxy on the elevator connector wire and tail wheel to rudder.
Old 10-13-2006 | 11:25 AM
Maudib's Avatar
My Feedback: (51)
Well that's that then...
