Seagull Yak?
#577
RE: Seagull Yak?
How good is the .60 engine seagull yak 54 performance ? would any of you go for it ? I live in México and fly at sea level, I will greatly appreciate your comments.
Thanks for your comments.
Merry christmas and excellent 08 to all you.
Rafa
Rafa
#578
My Feedback: (28)
TN
RE: Seagull Yak?
Well, just got in from flying mine this afternoon and I did manage to bend the wing tube. Didn't do anything that I though was that hard. We did straighten it back, but it does bend real easy. Going to order a carbon fiber one.
#580
RE: Seagull Yak?
well rip out the gear today was not a hard landing but the wheels hit a crack in the feild out it came
i think the gear dose not have a Enough flex in it
will a carbon fiber be better ?
#581
RE: Seagull Yak?
ORIGINAL: crycroft
It's nothing to do with not having enough flex, if you look close you will find that they have used hot glue to bond the gear plate in place and also the surfaces it glues itself on is not much, I modified mine by providing more area (used thick balsa) for the undercarriage plate to glue on and it's been ok now.
Alan
#582
RE: Seagull Yak?
ORIGINAL: alcarafa
Rafa
Rafa
wooooowwwwwwww very kind from you guys, Txs for all your help and comments [&o]!!!
Rafa
#583
WY
RE: Seagull Yak?
Looks like your question got posted in the wrong thread.
Answer NO
The Yak in this thread is a 90-120 sized plane a 60 would fly it like a J3 Cub.
Seagull makes a smaller YaK for 60 sized engines that would be OK
Answer NO
#586
#587
RE: Seagull Yak?
ORIGINAL: tkg
Answer NO
Answer NO
#591
RE: Seagull Yak?
ORIGINAL: matim32
hello, I`m new in the forum, my english is very bad
I need help..
I have one OS 91fx, Can I mount it in the yak54 from seagull?
I need help..
#592
RE: Seagull Yak?
Matim pues si puedes, pero no en el yak grande, no tendra suficiente potencia, volará ? si pero con muchas restricciones, mejor ponle un 4 tiempos minimo 125
#594
RE: Seagull Yak?
el yak que yo quiero comprar es este:
[link]http://www.mirax.cl/detalles.php?codigo=22489[/link]
me va a servir el 91 fx??
por lo que me dijeron tiene mucha potencia y no voy a tener problemas
#595
RE: Seagull Yak?
Matim el peso final de este modelo anda cerca de 4.500 kg si vuelas al nivel del mar volara hasta cierto punto bien, pero la desición final es tuya hay otra versión del yak 54 de seagull para 60 / 90 buscalo en www.horizonhobby.com
saludos.
Rafa
saludos.
Rafa
#596
RE: Seagull Yak?
Si, he visto el otro modelo.
Bue, veré que es lo que decido, tal vez compre el grande y el dÃ*a de mañana le pongo otro motor más potente, gracias por las apreciaciones
Saludos
Saludos
#597
FL
RE: Seagull Yak?
Hello,
I bought a yak 54 from seagull and put a O.S 120 ax. I'd like to know if the airplane can do hover with this motor.
Thanks for your help,
Royak
Royak
