 Feul filler ... >
Feul filler ...
Feul filler ...
Old 12-05-2006 | 06:09 PM
Squire's Avatar
Default Feul filler ...
Every plane I have had up until now I could get to the fuel line to the carb and also the vent line to the muffler. New ARF, Phoenix Decathlon, has the engine cowled in completely prohibiting access to either of these lines. The tank makes provision for a third "Fill" line. How does this work?? How do you know when the tank is full??? Could I use a Great Planes/Dubro fueler "dot"??? Where would I mount it??
Any help would be appreciated.
Phil
[email protected]
Old 12-05-2006 | 08:16 PM
aussiesteve's Avatar
Default RE: Feul filler ...
In my opinion the fuel dots are one of the best inventions around. I have them fitted to nearly all of my planes and have never had a problem with one.
I usually connect mine with a second "clunk" in the tank - this is so that I can drain the tank fully at the end of the day with ease. The exception to this is in my 3D planes because I am concerned that the two clunks will interfere with each other (I don't know if this is an issue or not).
Usually you can access the muffler pressure tap to remove the line when fuelling - if not, a simple tee piece from that line to a second dot will allow you to tell when the tank is full. I know some people that simply fuel their planes until fuel flows from the muffler. they usually have Pitts style mufflers and the pressure tap is below the exhaust outlet of the engine.
I usually mount my fuel dots on the cowling in a convenient place. You can cut off some of the excess length, as long as the seating area for the "O" ring lock is retained. I also use 3 different colored fuel lines Red for the exhaust line, Clear for the supply line to the carb and green for the filler line.
Old 09-11-2007 | 10:36 AM
My Feedback: (10)
Excellent response, just the information I was looking for.
Paul D.
