Reload this Page >
CMP Cessna 182 Building Thread-->the best scale Cessna 1.20 size ARF that is on the market!!!
Old 11-14-2012, 07:24 PM
  #1176
GhostWhisperz
Default RE: CMP Cessna 182 Building Thread>the best scale Cessna 1.20 size ARF that is on the market!!!
Hi, If you need help in the build, I have a complete guide with included pics, Page 40 Posts 990 - 999. Hope they help, glad people are still using this thread. happy building, if you need any help just ask
Old 11-17-2012, 03:57 AM
  #1177
GhostWhisperz
@ Tarolog1974.
Your translation is very good, easy to understand, use wood like plywood as this is the best way. iron will be to heavy, if you use iron it will be hard to remove excess weight, using wood you can always add if needed.
Old 11-19-2012, 07:06 PM
  #1178
bobbydee
ORIGINAL: GhostWhisperz
Howdy Ghostwhisperz and friends!
Im greatful for this thread! and plan on following it. Im starting my re-build of a cmp cessna 182/140 size.And I have started the re-build by starting at the begining. the begining of this thread.and already I have gottin very good, plane saving info.Im gonna read it all.
By the way...any windshields, wing struts or light kits layin around? Thanks somuch guys.....bob
Old 11-26-2012, 07:52 PM
  #1179
bobbydee
Started repairing my cmp cessna 182/140.Ive read all the posts up too page 21 and glad I did.I read were there is a possible update for the rudder and now I see why while fixing the rudder hindges.nothing to glue too.so I am trying to get 3 small piece's of hard wood in place in the rudder instead of one long piece. because of wieght.want to go pull-pull on the rudder with the servo up front and "Y"shaped control rod for elevator.then I gotta go up front and put the firewall back togetherwith fiberglass. loks like the motor got ripped off.Need to build a one inch firewall box to mount my supertigre 3000 too. the motor has a big round backplate too so that will put me out to the end of the cowl with the prop backplate.I wont spare the fiberglass on the firewall repair. I was thinking of lowering the fuel tank because of the inverted motor.the front wheel settup apears stock and its not bent so this plane must have takin a nose dive on the maiden!didnt get a cowl with it.bought a used one and glad to havit!hope the pics load.....bob
ID:	1823941   Click image for larger version
Old 11-27-2012, 02:11 PM
  #1180
SDCrashmaster
SDCrashmaster's Avatar
ORIGINAL: Tarolog1974
Hi guys. Who can find a picture of Cessna 182 with tail number N 1750 P?
Belongs to a 1954 Piper PA-18 in N. Dakota
Old 12-31-2012, 08:32 PM
  #1181
bobbydee
Howdy boys
Im trying to level the fuse to set up my engine.would appreciate any help on levelin the fuse.best to go off the inside braceing or top of fuse? thanks a bunch....bob
Old 02-03-2013, 06:28 AM
  #1182
phakur
My Feedback: (13)
Okay all-
I have searched through this thread and found several comments on folks intending on using a DLE 20 and several folks commenting that it is probably not enough engine. I happen to have DLE 20 available and it is looking for a homeI really like this plane but don't want it to be a dog (that is what I took the DLE 20 off of).
Has anyone actually put a DLE 20 on the plane and can they comment on how the plane flies, general maneuvering, prop size, etc.
Thanks much!!!
Larry
Old 02-03-2013, 06:56 AM
  #1183
GhostWhisperz
Hi there, Many have said thriugh this extensive thread that the power to weight ratio will not be enough, most mut a 26cc in, it will give the extra power to get you out of trouble if youneed it, ie abort landing. I have put a DLE 30 in mine, plenty of power and no extra weight. Please have a look through this if you would like to get a recommended engine size.
Hope this helps
Old 02-03-2013, 07:14 AM
  #1184
cannonball200
My Feedback: (36)
cannonball200's Avatar
I fly a GP Waco 72" ARF with a Dle 20 and it weighs 16#+. Has plenty of power. A Dle 20 would be plenty of power for this 182 and would be very scale like also. No need to fly it like a jet and hover, etc. I just bought one and it will get a Dle 20 for sure. An easy install also. All my flying friends that use the Dle 20 say it has more power than the 26's out there also. I use a 16/8 wood prop on my Waco and a 16/6 wood prop on my 1/4 scale Hanger 9 106" ws J-3 Cub also with the Dle 20 (weighs 14#'s). The J-3 fly's excellent with the Dle 20 also.
Eddie of OKC, OK
ID:	1847484   Click image for larger version
ID:	1847485   Click image for larger version
ID:	1847486   Click image for larger version
ID:	1847487   Click image for larger version
ID:	1847488   Click image for larger version
ID:	1847489   Click image for larger version
Old 02-03-2013, 07:31 AM
  #1185
GhostWhisperz
Thanks for replying to him with actual facts, I was only going by what others have said regarding the engine.
Old 02-03-2013, 02:00 PM
  #1186
HUNTERANDJEFF
I have a fuji bt 24 in mine and it is a gutless pig! I hate it and wish that I would have put a 30cc in it. In fact, I am going to sell the motor soon it is hardly broke in and runs excellent but it just isn't the motor for me...
http://www.youtube.com/watch?v=VI3lp...DFYyg&index=39
Old 02-04-2013, 07:10 AM
  #1187
phakur
My Feedback: (13)
Just to continue onI am not interested in unlimited vertical or anything close to 3D. Just want to make sure that I can do some loops and rolls, immelmanns, etc type maneauvering with a 20 cc engine.
I was really hoping that there was folks out there who have actually stuck a 20 cc DLE on the plane and can talk about it.
Thanks-
Larry
Old 02-04-2013, 07:30 AM
  #1188
HUNTERANDJEFF
Ok to continue on,
The dle and others are very light engines (which is great!). My fuji 24cc has a magneto and is heavy (about 4 lbs) and I didn't need weight up front. This plane requires alot of nose weight so with that engine, you may have to add up to 1 1/2 pounds up front to get her to balance. Wouldn't you rather have more engine up there instead of dead weight? You don't have to fly at full throttle all of the time but the power is there if you need it. Just sayin'
Old 02-04-2013, 08:23 AM
  #1189
GhostWhisperz
I agree with HUNTERANDJEFF,
 also to quote you
 "I was really hoping that there was folks out there who have actually stuck a 20 cc DLE on the plane and can talk about it"
I believe cannonball200 has already answered your question as he has stated he has put a DLE 20 in his Cessna 182
Old 02-04-2013, 09:25 AM
  #1190
cannonball200
My Feedback: (36)
I have not flown the 182 with the Dle 20 but, I have flown the heck out of my 16 lb GP Waco arf with the Dle 20. Pics are in a few posts above as well as the 14 lb Hanger 9 1/4 scale J-3 Piper Cub. The Waco has plenty of power with the 20 and will do large loops, barrel rolls and climb great. The 182 is not going to be anywhere close to the Waco weight. I fly the Cub and Waco at about 1/2 throttle most of the time also. I'm telling you all that the Dle 20 will be plenty of power to fly the 182 with athority and will fit good in the plane. I use a 2400 nicad 6 volt for radio and a 1500 nicad 4.8 volt for engine and you can shove them as far forward as possible for balance. Just install that Dle 20 on that 182 and go fly it.
Eddie of OKC, OK
Old 03-25-2013, 01:25 AM
  #1191
asif143
does any one tell me if i have o.s 46 la  max engine . then what should be the daimention  of cessna 182
Old 04-05-2013, 06:31 AM
  #1192
asif143
hello sir
can you tell me if i am using os 46la engine in cessna 182. so what should be the diamention of cessna 182 and weight
Old 04-05-2013, 08:47 PM
  #1193
nicolau
Hi asif.
If that 46 you want to use is a glow engine. I belive will not be powerfull to even get this plane rolling. I have 2 182 and I'm using Saitos4 cycle150 ,This iswhat I had availlable forpower source and they provide more than enoughf power. This is a very tail heavy plane, move all you can as far fordward as you can, balancecarefully, have your front landing gea a litle short of what it says on instructions and give about 4 degrees rake and you will have a very rewarding airplane,with a 10 degree flap forlanding she will land beatifully . Does not have any bad traits..I believe this plane was made for a 140 glow engine.
Good luck
Thanks Jose.
Old 06-01-2013, 06:18 AM
  #1194
1UGLYPUG
Hello again folks... I was talking to someone that wanted some of the plastic windows for the Giant Cessna 140, but can't remember who... I found the guy that I thought had some, and am going to see him today.,,, Please contact me or respond soon so I can get them from him before he throws them out. He got divorced and needs to get rid of his excess "inventory", as it is all in a storage unit .
Old 06-01-2013, 06:23 AM
  #1195
HUNTERANDJEFF
ORIGINAL: 1UGLYPUG
Hello again folks... I was talking to someone that wanted some of the plastic windows for the Giant Cessna 140, but can't remember who... I found the guy that I thought had some, and am going to see him today.,,, Please contact me or respond soon so I can get them from him before he throws them out. He got divorced and needs to get rid of his excess ''inventory'', as it is all in a storage unit .
It wasn't me but my windows turned yellow from gasser engine exhaust and I am going to have to replace them when I give my cessna a new paint job this winter. Also, I could use a new cowl and wingtips if he has them along with any other accy. he might have.
you can reach my email here
[email protected]
Jeff
Old 07-01-2013, 11:25 AM
  #1196
eric.ica01
eric.ica01's Avatar
Hello everybody ,
I am Eric from Réunion Is. and I am new in this forum .
Sorry for my english (I am french) , please I'm looking for the rear landing gear for CMPro Cessna 182 Skylane 140 ARF
 . My plane :
Please , can you tell me where I can get these parts ?
 I can't get informations on the Web and my plane is grounded  ...
Thank you for your help .
Eric
Old 03-24-2014, 06:16 AM
  #1197
sjanninck
Hello All,
I am just finishing up my CMP 182, and since the day I purchased it, I have been in search for One of the modeled Scale Antennas that reside on top of the wing over the fuselage. One was missing in the kit and Nitroplanes has been unable to replace it for me. Anyone have a spare they would like to sell, or has anyone found a similar replacement?
Thanks in advance!
Regards,
Steve
Old 03-24-2014, 07:51 AM
  #1198
FlyerInOKC
FlyerInOKC's Avatar
Steve would one from the Top Flite ARF work? I recently bought a pair to use on my TF kit 9saves me some carving) so I can measure them if you like and then you can order a set from Top Flite.
Old 03-24-2014, 03:28 PM
  #1199
sjanninck
Hello FlyerInOKC,
I have tried to get a PN for the Top Flight antennas, and was unable to locate. do you have a PN?
Steve
Old 03-24-2014, 03:55 PM
  #1200
aramsdell
Steve check your PM's I sent one a couple hours ago.
Al
