H9 Cap 232 1/4 Building ? >
Old 02-12-2002 | 08:53 AM
Default H9 Cap 232 1/4 Building ?
[SIZE=4][FONT=courier new][COLOR=blue]
Hi just putting the cap together and i can,t see in the instructions
the distance between the fire wall and the prop hub on the motor.
Is there a correct distance ? or do i ajust the motor for CG. PS Its a 160FX but i don,t think that matters. Thank you for your help.
Old 02-12-2002 | 12:04 PM
The distance is going to end up being about 6 inches, just make sure the cowl covers opening in top of fuselage. I installed my engine as far out as possible, making sure the fuselage opening is covered. Daz...
Old 02-12-2002 | 01:34 PM
I installed my Saito 1.80 as far forward on the mount as possible.
Adrian
Old 02-15-2002 | 03:36 AM
I used the cowling as my guide,as far out as you can get away with.
