2 cycle engine
My Feedback: (94)
Inverted will work just fine, the only problem mounting an engine inverted is that the engine can flood a lot easier seeing how the glow plug is at the bottom. Just try not to prime the engine to much before you start it, you may notice a little richer low end after idleing for a long time. The .91fx is a great engine, if your plane will look best with the engine inverted by all means do it.
