H9 Edge Saito 180 Prop?
My Feedback: (67)
IN
Hello those of you with the saito 180 and the H9 edge what prop are you running for good 3-D? What brand and size? Thanks in advance for your replies. Happy flying!
My Feedback: (23)
I have just switched to this prop from 17X8 apc...
I only have about 5 flights with this prop so I have not decided if i like it or not yet...
so far this is what I have found
17X8 apc 9100 rpm...%15 % nitro
18X6W apc 8500 rpm 15 %
reliable idle 17X8...1500
reliable idle 18X6W 900-1100 (no onboard glow)
18/6 seemed to slow the plane way down...almost scary slow...(cap232)
torque rolling is a bit easier
My Feedback: (23)
yes....big spinner work required on a dave brown spinner.
I think there are spinners available that are cut for wide props...mine wasn't one of them.
everything seems a bit slower swinging the bigger prop...including pulling out of torque-roll.....12.75 lb +15% nitro= slow pull out no matter which prop
