zen 30
Old 05-23-2007 | 09:51 PM
Default zen 30
I've got a OS28fsr w/macs tuned pipe. I thinking of getting a Zen 30 for it. Has anyone flown the Zen with a 25size 2 stroke? I've searched the posts but didnt get a good answer.
Mark
Old 05-23-2007 | 09:59 PM
piper_chuck's Avatar
My Feedback: (12)
Default RE: zen 30
It's a fairly big plane. I don't think the .28 FSR would have enough power to fly it to its potential.
Old 05-23-2007 | 10:20 PM
Default RE: zen 30
Thats kinda what I was thinking. Just wanted some opinions.
Since its shows a 40 4 stroke, maybe a lite LA40 or 46 would work better.
Old 05-24-2007 | 09:28 AM
My Feedback: (12)
Default RE: zen 30
ThunderTiger Pro .36 fits nicely under the cowl. Other.36 engines would too.
Old 05-24-2007 | 07:44 PM
Default RE: zen 30
I have a Zen 30 which I have been flying for about 4 years now with an OS 48 Surpass. Great engine with lots of power for this plane. I do not get into 3D so the 48 is more than adequate. If you want to get lots of power use a Saito 56 four stroke.
Flashingredd
Old 05-24-2007 | 08:39 PM
Default RE: zen 30
I'm still thinking about it. I dont do 3d and I dont think I ever will. I like to fly the sportsman pattern manuvers. The Zen 30 has a 46" w/s and 463 w/a. Weight of 4#. The .28 w/tp should fly the sportsman pattern. I dont need unlimited vertical, but I do need enough. The la40 weighs about the same as a .28 or .36 engine. It will swing a prop from 9x7 to 11x4. I have both engines[.28os and la40].
On your .48 fs did yours require alot of tail weight? How much was the total weight? Last but not least, are you happy with the kit and flight performance?
Mark
Old 05-25-2007 | 06:28 AM
Default RE: zen 30
antique opa
I did not have to add any additional weight. I was ab;e to move the battery around to acheive proper balance. Verticle is not unlimited but is much more than adiquate. I am very happy with the Zen 30 since it is small enough to take to the field without disassembly or reassembly although it would require two servo wires to be plugged in and two wing bolts screwed down. I am very happy with flying charastics but I like to fly bigger planes. I would like to try a Zen 90 some day when the pocket book will allow.
Good luck with yours. If you do not want to go 4 stroke and are looking for good power, think about an OS 32 SX.
Flashingredd
Old 05-25-2007 | 08:20 AM
My Feedback: (27)
Default RE: zen 30
I have the Zen 30 that I fly with a Leo 37 on a pipe. I got the engine and pipe from Just Engines. This seems to me to be a nice combination. I would think that the TT 36 would work as good.
Pete
Old 06-07-2007 | 05:18 PM
Default RE: zen 30
will the zen fly good whit an OS 46 FX ?? i have a brande new ZEn 30 and wood like to hear your opinion on engine choise..
also haow dose this plane handel?? what setup do you have on your ZEN?
i have a ZEn 90 also and it is a very good plane.
Old 06-07-2007 | 09:33 PM
Default RE: zen 30
Lovinero,
The OS 46 FX is most likely over kill but I am sure the frame will handle the added power. If proped correctly you will have a rocket ship. I used a four stroke and had no difficulty with speed or power. You will find that the ZEN 30 will fly just like the ZEN 90.
I have never had a bad flying plane from World Models.
Flashingredd
Old 09-18-2007 | 04:17 PM
Default RE: zen 30
i was thinking about putting the hitech 5245mg mini servos in this plane. does anybody know if this would work without having to add on to the servo holes? thanks for the help.
Old 10-11-2007 | 09:17 PM
Default RE: zen 30
I have a zen 30 w/enya 53 4strok perfect match
Old 11-26-2007 | 02:05 AM
Default RE: zen 30
the FX 25 works just fine for sport flying!!!
Old 11-26-2007 | 02:07 AM
Default RE: zen 30
This is a very cool little plane by the way!
Old 11-26-2007 | 04:55 AM
forestroke's Avatar
Default RE: zen 30
the zen30 with the TT36 is a rocket!!! i couldn't believe the speed it had... i think the 28 would be a better match for standard and pattern. they 36 basically made it a racer, which it wasn't designed to be!
